Pic12f675 Serial woes
Results 1 to 2 of 2
    Apr 2009
    Default Pic12f675 Serial woes
    Hello all
    I'm sorry if this is a silly question, but I am trying to get my pic to send a txt string to a PC running hyperterminal.
    The code looks something like this, though it may not be exact because my work is at the office.
    Device 12f675
    (some options WTD etc)
    XTAL 4
    ALL_DIGITAL True
    Output GPIO.0
    DelayMS 1000
    Serout GPIO.0, 16572, ["This string won't come through]
    Goto Main
    I need to use 4800 bps 8 bit and no parity ( I think) for NMEA strings, but I can't seem to get the data through.
    If I drive an LED on the output, I can see that there is some data coming through, but it must be in the wrong format.
    Also, I have connected GPIO.0 and GND straight to the PC serial port pins 2 and 5.
    Any help would be most appreciated
    You should try the Proton forum at http://www.picbasic.org/forum
    This forum is for PicBasic Pro.
  1. Pic12F675 serial voltmeter
    By GioppY in forum Code Examples
    Last Post: - 20th November 2010, 13:20
  2. Dynamic USB Serial Number (PIC18F4550)
    By awmt102 in forum mel PIC BASIC Pro
    Last Post: - 16th July 2009, 17:03
  3. PIC12F675 problem with port 5
    By NL2TTL in forum mel PIC BASIC
    Last Post: - 5th June 2009, 01:23
  4. SERIN with a PIC12F675
    By ewandeur in forum Serial
    Last Post: - 30th July 2007, 15:04
  5. PIC12F675 trouble
    By russman613 in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 18:40
