Can someone help me make a code for this:
Results 1 to 10 of 10
    Jan 2006
    Istanbul
    Delete VRCON = 0, try again.
    Also,
    VAL is a WORD variable thus it has 16-bits.
    But, in the sample code, we have 15 bits (15 LEDS) getting set.
    Depending on the pic you are using, add one more led to an appropriate pic pin, and assign it to the last bit of VAL (Val.15) in SetPins subroutine.
    Apr 2009
    i think the problem is on the configure bits ???
    i changed the pause 5000 to 100 and run it on simulation and i noticed that led's connected on RA6 and RA7 is never energized, what could be the problem?
    It all depending of our device in use, some have ADC, some have analog comparator, some have open-drain, and the list is almost endless. But there's less chance that any issues would be caused by a timer.
    I suggest you to have a look at this link.
    http://www.picbasic.co.uk/forum/showthread.php?t=11116
    Remember, datasheet MUST be your friend
    Apr 2009
    I changed the start of the code
    @ DEVICE PIC16F628A, INTRC_OSC_NOCLKOUT, WDT_OFF, PWRT_OFF, MCLR_OFF,PROTECT_ON,CPD_ON, BOD_OFF, LVP_OFF
    it was a part of the comments before
    and changed
    FOR Index = 0 TO 15   ' Scan through the bits.
    to
    FOR Index = 0 TO 14   ' Scan through the bits.
    and the final code:
    CMCON = 7
    PAUSE 1
    VRCON = 0
    PAUSE 1
    TRISA = 0
    TRISB = 0
    PORTA = 0
    PORTB = 0
    T1CON.1 = 0
    OPTION_REG.5 = 0 ' Internal clk.
    OPTION_REG.3 = 0 ' Prescaler assigned to TMR0.
    OPTION_REG.2 = 0 '
    OPTION_REG.1 = 0 '
    OPTION_REG.0 = 0 ' 1:1
    PAUSE 10
    Led1 VAR PORTA.0    'Assign leds.
    Led2 VAR PORTA.1
    Led3 VAR PORTA.2
    Led4 VAR PORTA.3
    Led5 VAR PORTA.4
    Led6 VAR PORTB.0
    Led7 VAR PORTB.1
    Led8 VAR PORTB.2
    Led9 VAR PORTB.3
    Led10 VAR PORTB.4
    Led11 VAR PORTB.5
    Led12 VAR PORTB.6
    Led13 VAR PORTB.7
    Led14 VAR PORTA.6
    Led15 VAR PORTA.7
    Index VAR BYTE
    LookForThree VAR BYTE
    Val    VAR WORD
    Result VAR BYTE
    PAUSE 100
    Start:
        LookForThree = 0
        WHILE LookForThree <> 3   ' Look for three "SET"s.
            RANDOM Val            ' Get a random value.
            PAUSEUS TMR0          ' To get a good random number, have a changing value using TMR0 or TMR1.
            LookForThree = 0
                IF Val.0[Index] = 1 THEN LookForThree = LookForThree + 1 'Count "SET"s.
                NEXT Index
        WEND
        GOSUB SetPins
        PAUSE 1000
        GOTO Start
    SetPins:
        Led1  = Val.0
        Led2  = Val.1
        Led3  = Val.2
        Led4  = Val.3
        Led5  = Val.4
        Led6  = Val.5
        Led7  = Val.6
        Led8  = Val.7
        Led9  = Val.8
        Led10 = Val.9
        Led11 = Val.10
        Led12 = Val.11
        Led13 = Val.12
        Led14 = Val.13
        Led15 = Val.14
    it's now working good hooray! thanks for your help pips more power!
    Apr 2009
    and oh i forgot i just switched to PIC16F628A
  1. Code doesn't work on 16F648A
    By Mr_Joe in forum mel PIC BASIC Pro
    Last Post: - 1st September 2018, 23:09
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  5. Making Program Code Space your playground...
