Storing Data - 16f690
Results 1 to 4 of 4
    May 2009
    Default Storing Data - 16f690
    I'm new to all this, a couple of questions.
    Using a 16f690 is it possible to store data to the program location so that it remains there and can be read back after a power cycle ?
    Also can someone point me to where I can find what the Device Declaration statements mean. I have looked on the datasheets but it's not exactly plain english to me.
    Example -
    @device pic16F690, intrc_osc_noclkout, BOD_OFF, PWRT_OFF, wdt_off,mclr_off,
    ' protect_off
    Cheers
    Adam
    In some case yes, but it's way more convenient/standard to use the internal EEPROM with READ/WRITE.
    May 2009
    Is it possible to permenantly store data using the write command, even after a power cycle, if so how ?
    Cheers
    Adam
    May 2009
    Told you I was new to this.
    I actually had the code correct but beacuse my test board is connected to the low count demo board and the PICkit2 programmer, it doesn't keep the saved eeprom values after a power cycle.
    Running it on a 3v battery instead of the PICkit2 usb power, it works as it should when using the Read and Write commands as you suggested.
    Cheers
    Adam
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
