Self update of devices
Results 1 to 18 of 18
    I'm using PICBASIC PRO™ version 2.45. Is there a way to add support for the PIC16F727? I don't see it in the drop down in MCS 3.0.0.5.
    ~ Dave
    You could try creating your own INC and BAS files - you 'might' be lucky and that could be all that was needed... but more complex features may have required changes to the core compiler itself. Try it and see... but upgrading is so cheap anyway, treat yourself to a Christmas prezzy...
    Not quite relevant to this thread, but it does concern Microcode Studio Plus. I've been using the 16F88X chips quite a bit, and would love to see MCSP ICD support for these. I wrote to Mecanique a couple of times but got no response.
    There was a thread pertaining to this issue http://www.letbasic.com/forum/showthread.php?t=4945 where David gave a link for an updated set of ICD files, but although the 16F88Xs are listed, they do not exist in the actual download.
    Is there a way to add this support oneself?
    Anand
    Which compiler do you refer too??
    PBP 2.47, MCSP 3.0.0.5.
    Anand.
    2.47 supports the F88x chips. This has nothing to do with MCS.
    If the compiler supports the PIC then so does MCS.
    Maybe your issue is something else. Are the *F88x.bas and *F88x.inc files present in your PBP directory??
    No, I think you've misunderstood the issue; I am referring only to the MCSP ICD capability for these chips.
    Anand
  1. Composite USB Devices
    By Kamikaze47 in forum PBP Wish List
    Last Post: - 18th May 2008, 08:51
  2. Update your HyperTerminal !!
    By Darrel Taylor in forum General
    Last Post: - 25th November 2007, 21:26
  3. Melabs PIC Basic Pro - 16 bit devices support
    By rod27cn in forum PBP Wish List
    Last Post: - 21st November 2007, 09:21
  4. Two USB devices with same software, easyHID
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 07:19
  5. How can I update my compiler 2.46 to 2.47 ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 13:35
