Self update of devices
Results 1 to 18 of 18
    Default Self update of devices
    I am sorry if this has been covered before but cannot find it.
    I want to add support to Microcode Studio and PBP for the 16F727 device (relatively new).
    Most of the registers are common with other chips, but how can a new .inc file make the Microcode studio and PBP aware of the new file?
    I wish they updated the files more often...
    Talking
    Hi, Ioannis
    ;* 16F727.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2008 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 04/21/08 *
    ;* Version : 2.50b *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F72x.INC' ; PM header
    device pic16F727, XT_osc, wdt_on, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F727, r = dec, w = -302
    INCLUDE "P16F727.INC" ; MPASM Header
    __config _CONFIG1, _XT_OSC & _WDT_ON & _CP_OFF
    NOLIST
    LIST
    #define EEDATA PMDATA
    #define EEADR PMADR
    #define EEDATH PMDATH
    #define EEADRH PMADRH
    #define EECON1 PMCON1
    But, I keep on thinking Downloading the PBP 2.50 "C" PATCH wouldbe simpler than pasting that file into your directory ...
    PICBASIC PRO(TM) Compiler 2.50c, (c) 1998, 2008 microEngineering Labs, Inc.
    regards
    Alain, who posted a while ago about this the new relase ... Never read Friend's Posts ??? Booooooooooooooooooooooo !
    Sorry my dear friend, I guess I missed that post! I also did not notice that there is new patch for the compiler. Sure I will update soon. Now where did I put that receipt....
    One more. I tried to edit the .ini file in the Microcode studio directory,but seems it has no effect on the menu selection. It still shows the same PICs as before the edit. Any tip on this?
    I just tried it myself here and, it seems the latest version of MCS don't care if you add device in the pic.ini list. So in theory, MCSP should scan the .INC file in your PBP folder and build a list automatically.
    Hm, intersting. Yes, it searches the PBP file for the *.bas of the relevant PIC and not the .inc.
    I made a copy of file, changed to *aa.bas and voila! It showed up in the drop down list.
    This means that when you update the PBP Compiler, you have Microcode already updated!
    Nice.
    I'm using PICBASIC PRO™ version 2.45. Is there a way to add support for the PIC16F727? I don't see it in the drop down in MCS 3.0.0.5.
    ~ Dave
    You could try creating your own INC and BAS files - you 'might' be lucky and that could be all that was needed... but more complex features may have required changes to the core compiler itself. Try it and see... but upgrading is so cheap anyway, treat yourself to a Christmas prezzy...
    Not quite relevant to this thread, but it does concern Microcode Studio Plus. I've been using the 16F88X chips quite a bit, and would love to see MCSP ICD support for these. I wrote to Mecanique a couple of times but got no response.
    There was a thread pertaining to this issue http://www.letbasic.com/forum/showthread.php?t=4945 where David gave a link for an updated set of ICD files, but although the 16F88Xs are listed, they do not exist in the actual download.
    Is there a way to add this support oneself?
    Anand
    Which compiler do you refer too??
    PBP 2.47, MCSP 3.0.0.5.
    Anand.
    2.47 supports the F88x chips. This has nothing to do with MCS.
    If the compiler supports the PIC then so does MCS.
    Maybe your issue is something else. Are the *F88x.bas and *F88x.inc files present in your PBP directory??
    No, I think you've misunderstood the issue; I am referring only to the MCSP ICD capability for these chips.
    Anand
    No I did not. MCS capability depends oin the compiler.
    Including the MCS in-circuit debugging capability?
    Anand
    Are you using the PRO version or the freebie? I have the pro version and while I do not use it, it seems to support that PIC.
    MCS Pro.
    Does the folder "ICDModels" in your install have a file for 16F88x? Mine doesnt. Alphabetically sorted, after 16F877A mine jumps to 16F913.
    Anand
    MCS Pro.
    Anand
    "ICDModels" ? I just have a bunch of buttons like ICD Compile, RUN . . . that work when 16F88 is selected. Try the Online Updates from the View Tab. Maybe your version is too old. They have never charged me for an update either, only the initial purchase of the Pro version.
    "ICDModels" ? Try the Online Updates from the View Tab. Maybe your version is too old. They have never charged me for an update either, only the initial purchase of the Pro version.
    I am referring to a folder called "ICDModels" within the main MCS Plus folder which contains .icd files for all the supported chips. I too have been able to update periodically after the initial purchase some years ago.
    The 16F88 never was a problem; its only the 16F886, 16F887 etc. that I'm referring to.
    Anand
  1. Composite USB Devices
    By Kamikaze47 in forum PBP Wish List
    Last Post: - 18th May 2008, 08:51
  2. Update your HyperTerminal !!
    By Darrel Taylor in forum General
    Last Post: - 25th November 2007, 21:26
  3. Melabs PIC Basic Pro - 16 bit devices support
    By rod27cn in forum PBP Wish List
    Last Post: - 21st November 2007, 09:21
  4. Two USB devices with same software, easyHID
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 07:19
  5. How can I update my compiler 2.46 to 2.47 ?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 13:35
