Hi Mister E,
Thanks for stepping in there. I kinda got off track with his original question!
BobK
Hi Mister E,
BobK
Thank you gentlemen,
what I had (crucially!) forgotten to add, was that the program on the pic would stop working entirely when the more than two segments were on at a time. I have since found that it must be due to the PIC's current sourcing limitations (is this correct?). Regardless, I have added some CD4050BE buffers and now it all works fine.
I really appreciate your time and expertise. thank you.
Ps Not using a LCD as I don't have one! Beside, there's something appealing, almost 'retro' about 7 segment displays I find....
Code:test code tags
Hi Steve + Clocks
You do not use 105, but 4 x 105 mA ... ( no multiplexing !!! )
so, at least 2v * 420 mA = 850 mW to dissipate in the 7805 !!!
some cooling necessary then !!! ( 10° C/W will be Ok )
Hi Alain,
Indeed - no multiplexing (I need bright displays).
How do cool this down - or are there high rated voltage regulators out there?
I don't understand your last sentence; what is : 10° C/W?
thanks for your help!
It's the thermal resistance of the dissipator to use ... it's like Resistance's "Ohms" ... but for heat dissipation value.
That means it will heat at a rate of 10°C per dissipated Watt ... in your design, the temp of dissipator will be ( at blind sight ! ) ~ 25°C + (2 x 10°C) = 45°C
