18F4431 - Complementary mode PWM
Results 1 to 13 of 13
    Brussels, Belgium
    Default 18F4431 - Complementary mode PWM
    I'm using the power control module of a PIC18F4431 to control some Constant current sources for some high power leds. For these CCS devices a "1" = "off" so I though to myself why not use the complementary mode on the PWM module then on my even channels I'll get 1's and on the odds 0's. Wrote a little code to ramp the leds up and down but the even channels are staying at full power while the odds are ramping as expected. If i put it into independent mode all leds ramp together so it isn't something I've snafu'd on the ccs connections.
    Here's the code, any idea where I'm going wrong ?
    define OSC 20
    Duty Var Word
    PORTB = 0 ' clear port
    TRISB = %11000000 ' PWM0,1,2,3,4,5 outputs
    ' set up PWM
    DTCON = 0 ' 0 dead-time
    PTCON0 = %00001000 ' 1:1 postscale, 1:16 prescale, free running mode
    PTCON1 = %10000000 ' PWM time base is ON, counts up
    PTPERL = $E8 '
    PTPERH = $07 ' PTPER = $07E8
    PWMCON0 = %01000011 ' PWM 0 to 5 outputs enabled , complementary
    PWMCON1 = 1 ' updates enabled and overrides sync
    OVDCOND = %11111111
    RAMP:
    For Duty = 2024 To 0 STEP-1 '
    PDC0L = Duty.LowByte
    PDC0H = Duty.HighByte
    PDC1L = Duty.LowByte
    PDC1H = Duty.HighByte
    Pause 5
    Next Duty
    For Duty = 0 To 2024 '
    Pause 5
    Next Duty
    GoTo RAMP
    Thanks, Andrew
    AndrewC, It looks like its time for an inverter or transistor...
    Brussels, Belgium
    ... or even just calculate new_duty= period-old_duty but I'd like to figure out how to make it work
    Hi Andrew,
    I'm not very familiar with the PWM modules on those chips.
    But Bruce did an example with a scope image of the output, and the waveform looks like what you want. But the register settings look completely different.
    using the pwm's in pic18f2431-2331-4331-4431
    http://www.picbasic.co.uk/forum/show...3820#post43820
    If you set a fixed duty cycle of 50% it should work pretty much the same in either mode.
    But if you're going to cycle through changing the duty cycle, you're better off using it with
    independent mode for driving LEDs.
    Look at the attached graphic. Note how signal 0 & signal 1 would make it look like one LED
    was on all the time, while the other was off all the time. Complementary mode is for driving
    N channel & P channel motor drivers. It's a lot different than standard PWM.
    If the duty cycle was say 70%, one pin would be high for 70%, the other would be low for
    70% since they're complementary.
    Signals 2 & 3 are in independent mode, so the high duty cycle is the same for each pin.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Brussels, Belgium
    Thanks for the answers.
    Darrel: thanks for the pointer to Bruce. I've got the registers set for a much lower frequency than Bruce's example - my CCS can only work at 200Hz max so I should be running at 154Hz with the values I've picked. Also I made sure with OVDCOND that nothing is over riding the PWM. Well, that's what I think I was doing
    Bruce: so what I want is the behaviour you show for 0 and 1, I want to output the inverse of the programmed duty cycle. What I see is PWM.1 ramping up and down while PWM.0 seems to stay constant. If i put them into independent mode (PWMCON0 = %01000011) then PWM.0 and PWM.1 ramp up and down together - same as your signals 2 and 3 - which sanity checks my wiring.
    Alas I don't have a logic analyser (until a parcel arrives from Saleae) to check so I'm basing my judgement on the led intensity.
    What I'm using this for is LED illumination of a macrophotography stage - in continuous PWM I get what we call modelling light then for an actual shot I'm planning to switch to a single shot so I can get aligned "strobe" pulses of three different lengths from a group of three PWM outputs. There are undoubtedly many different ways to do this but I thought it was an elegant way of using the 18F4431 capabilities, if I can figure out where I've gone wrong.
    rgds, Andrew
    Hi Andrew,
    I think I see the problem. Give this a shot and let me know how it looks;
    DEFINE OSC 20
    Duty Var Word
    ' set up PWM
    PTPERL = $E8 '
    PWMCON0 = %01000000 ' PWM 0 to 5 outputs enabled , complementary
    OVDCOND = %11111111
    RAMP:
    For Duty = 8000 To 0 STEP-1 ' ~3.2% to ~99%
    Pause 5
    Next Duty
    For Duty = 0 To 8000 ' ~99% to ~3.2%
    Pause 5
    Next Duty
    GoTo RAMP
    -Bruce
    tech at rentron.com
    May 2011
    Default Re: 18F4431 - Complementary mode PWM
    Hi
    I am using 18f4431 ,too.I want to run AN900 (microchip).I were unable to send.This program ,it works isis.But I were unable to run 18f4431.
    Please help me.
    Without your code it's hard to say. But if it runs in isis and not in the actual circuit.
    The problem is probably in your configuration settings. Did you set the High-side/low-side transistor polarity?
    Post your code and configurations and someone will help.
    May 2011
    Hi Mark_s , I would like to apologize for that I enter conversation between. I am new in the pic issue.I &nbsp;dont know configuration settings.Only do you need to hex file?
    https://rapidshare.com/files/854468532/AN900DNM.rar
  1. 18f4431; driving a stepper IN HARDWARE mode
    By DDDvvv in forum mel PIC BASIC Pro
    Last Post: - 21st January 2010, 16:49
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 22:18
  3. switch mode power supply with PWM
    Last Post: - 14th July 2009, 20:51
  4. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  5. 18f4431 pwm4 and pwm 5 issues
    By lothar in forum mel PIC BASIC Pro
    Last Post: - 9th April 2009, 16:48
