RA7/CLKIN as analog input
Results 1 to 4 of 4
    Default RA7/CLKIN as analog input
    hello
    in an existing environment i want replace a 16C58 with an 16F628A. originally at the CLKIN (RA7) there was an potentiometer. how can i read in analog this pin and must configure them?
    thanks for an idea and greetings
    Use POT or RCTIME statement. Must add an external capacitor prior to make it work. Input must be set to analog too. CMCON=7.
    thanks for the information, unfortunalety it doesn't run...
    can you tell my link where CNCOM is described online?can't find a good information
    POT and RCTIME are described in the PBP Compiler Manual, but im not sure if my code is arranged right
    could you tell me a short example in PBP?
    thank you very much
    this one comes from Melabs code example
    ' PicBasic Pro program to read pot and display on LCD
    ' Define LCD pins
    Define  LCD_DREG        PORTA
    Define  LCD_DBIT        0
    Define  LCD_RSREG       PORTA
    Define  LCD_RSBIT       4
    Define  LCD_EREG        PORTB
    Define  LCD_EBIT        3
    ' Allocate variables
    x       var     byte
            CMCON = 7               ' Set PORTA to digital
            Pause 100               ' Wait for LCD to start
    mainloop: Pot PORTB.0, 127, x
            Lcdout $fe, 1, "pot=", #x       ' Send value to LCD
            Pause   100             ' Do it about 10 times a second
            Goto    mainloop        ' Do it forever
    in the PBP you have also one code example for POT and the according schematic. BTW if you don't have any book on hand, they provide one online
    pdf:
    http://www.melabs.com/downloads/pbpm304.pdf
    Html:
    http://microengineeringlabs.com/resources/pbpmanual
    CMCON is the register for analog comparator of the PIC16F628. You'll find it in the datasheet section 9.0
    datasheet:
    http://ww1.microchip.com/downloads/e...Doc/40300c.pdf
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. Analog input on 18f252
    By kiteman in forum mel PIC BASIC Pro
    Last Post: - 12th January 2009, 09:34
  3. Analog Input on PIC16F88
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 6th May 2008, 23:49
  4. 16f88 - pin RA4 as analog input
    Last Post: - 15th December 2006, 14:55
  5. Analog pins for digital input
    Last Post: - 9th September 2005, 01:32
