Code Copying/Transfer
Results 1 to 3 of 3
    Apr 2009
    Unhappy Code Copying/Transfer
    I have a programmed PIC 12F675 and I wish to extract the programme and "burn" it onto another PIC 12F675.
    I am using a Velleman K8048 programmer along with their supplied Progpic2 and MPASMWIN. I have been able to "READ" the chip and this give me a file (.txt) called readback.
    My question is please how do I use the kit I presently have to send this data back to a fresh PIC 12F675. I cannot compile the READBACK file as it gives 153 errors out of 155 lines.
    Any help would be greatly appreciated as I have spent days playing around with this and am getting no further forward.
    Kind regards
    Tony
    If you can read the code from your original 12F675, then it must not be code protected.
    Just change the name of the code read from the 1st PIC to whatever.HEX, and program
    the 2nd PIC with the saved .HEX file.
    You can't re-compile a .HEX file.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Apr 2009
    Smile Thanks
    Bruce,
    thanks for the update. I will give this ago at the weekend when I get some more time.
    Kind regards
    Tony
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
