character return from PIC to VB
Results 1 to 7 of 7
    Have you test the code with a simple program like terminal and give the numbers by hand and slowly ?
    What about you VB code?
    Your Crystal, Trimming Capacitors or a hundred other things could be affecting the Oscillator frequency. Looks like it's slightly off for your fast baud rate.
    Drop your communications down to 2400 and work up from there. You'll discover there will be a point where unacceptable errors start creeping in.
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. Comm example: Pic to Pic
    By Chadhammer in forum Code Examples
    Last Post: - 15th November 2006, 00:26
  3. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 19:31
  4. USB, PIC18F2550 and VB
    Last Post: - 27th November 2005, 19:37
