character return from PIC to VB
Results 1 to 7 of 7
    Jul 2008
    devon
    Default character return from PIC to VB
    Hi, I'm testing the serial communication between a 16F876 and a VB6 application. I read HSERIN then send it straight back out as HSEROUT. But I don't always receive the character I sent. eg:
    Sent to PIC Recieved back to VB
    1 ±
    2 ²
    3 3
    4 '
    5 5
    6 6
    I'm obviously not using the correct code table but I'm not sure what character set to use. Can anyone help?
    Ta
    Feb 2009
    Southern California
    can you post your code?
    Jul 2008
    devon
    Here is the PIC code. I am sending the data as a string from a TextBox in Visual Basic. By the way, the "END" is returned as "ÅND" if this gives any further clues!
    @ DEVICE HS_OSC,LVP_OFF,WDT_OFF,PROTECT_OFF,BOD_OFF,PWRT_OF F
    'declare variables
    define OSC 20
    DEFINE HSER_BAUD 19200 'serial
    DEFINE HSER_RCSTA 90h 'serial
    DEFINE HSER_TXSTA 24h 'serial
    DEFINE HSER_CLROERR 1 ' automatic clear overrun error
    DEFINE HSER_EVEN 1
    DEFINE HSER_BITS 7
    trisb = %11000000 ' set port b 0-5 o/ps 6&7 i/ps
    RCIF VAR PIR1.5
    SERIALDATA VAR BYTE
    portb.0 = 0
    portb.1 = 0
    portb.2 = 0
    portb.3 = 0
    PAUSE 100
    MAIN:
    portb.0 = 0
    IF RCIF THEN
    sound portb.0,[60,10]
    HSERIN [SERIALDATA] 'RCIF is reset by reading HSERIN
    HSEROUT [SERIALDATA,"E","N","D"]
    GOTO MAIN
    Have you test the code with a simple program like terminal and give the numbers by hand and slowly ?
    What about you VB code?
    Your Crystal, Trimming Capacitors or a hundred other things could be affecting the Oscillator frequency. Looks like it's slightly off for your fast baud rate.
    Drop your communications down to 2400 and work up from there. You'll discover there will be a point where unacceptable errors start creeping in.
    See what this does:
    HSEROUT[IDEC,SERIALDATA,"END"10,13]
    It should display Decimal digits, no modifyer should display ASCII, and HEX . . .Have not tried it, modifyer might make a mess out of the string "END"
    Actually there should be a comma after END... - Melanie
    HSEROUT[IDEC,SERIALDATA,"END",10,13]
    Jul 2008
    devon
    Thanks for the quick replies.
    After trying the PBP Serial Comm I realised I had not configured the Port correctly in VB ie Was 19200,N,8,1 should be 19200,E,7,1 as in the PBP code config.
    Simple mistake made by a now wiser person!
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 00:52
  2. Comm example: Pic to Pic
    By Chadhammer in forum Code Examples
    Last Post: - 14th November 2006, 23:26
  3. VB sending serial data to PIC
    By Tissy in forum Serial
    Last Post: - 8th March 2006, 18:31
  4. USB, PIC18F2550 and VB
    Last Post: - 27th November 2005, 18:37
