how to control the incoming data?
Results 1 to 8 of 8
    Apr 2009
    Default how to control the incoming data?
    How can I control when data is incoming? I have a pcb with Max232 and it sends/receive data, this is a portion of the code:
    'Waits 200ms until 129 is received, then store next byte in I, if timeout jump to M2
               SERIN SERIAL_IN,BPS,200,M2,[129],I
    This works ok but I loose 200ms waiting for data and that PCB needs to control more things, so it becomes slooooooooow. If I change it to 100ms it loose commands, if I use 500ms it works perfect, but then the rest of the code has no time to do its job.
    I can't use interrupts because the PCB uses PORTB.7 for SERIAL_IN.
    I've tried a "stupid way" (and obviosly it does not works):
         if SERIAL_IN=0 then       'something is changin in the RX PORT
    but the data received usually is corrupted. Then I've tried to repeat the commands from the PC (129-22-129-22) but also does not works ok.
    Any idea of how can I make this works better?
    Yes there is an excellent way and is called DT-Instant Interrupts!
    Apr 2009
    But that way is intended to use the INT port. I'm using a PCB with 16F628A, INT=RB0, and the port I must observe is RB7, so I can not see how to use Darrel's way
    It seems you do not read, or not read carefully.
    Your PIC has USART.
    USART has Interrupt that has nothing to do with PORTB.0 INT interrupt.
    Darrels Interrupts cover all possible Interrupt sources of a PIC. You just have to enable th appropriate interrupt.
    Example follows. On a terminal press key "1" to see the effect. (Not tested...)
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System
    	INT_Handler   RX_INT,	 _Get_char,	 PBP,  yes
    @ INT_ENABLE  RX_INT	   ; enable UART RX interrupt
    loop:
    if mybyte="1" then
        hserout "I got it!"
        mybyte=0
    goto loop
    '---[USART RX Interrupt handler]----------------------------------------------------
    Get_char:
    	hserin 100,noreceived,[mybyte]	'Get byte
    noreceived:                         'or if timeout return
    @ INT_RETURN
    P.S. As a homework do set the USART parameters with DEFINE's to 9600
    Apr 2009
    Your PIC has USART.
    I'm not english spoken, but USART is on RB.1 (RX), I can not use that PIN, just RB.6 for incoming data, and RB.6 as far as I know, can not be managed with interrupts.
    It's a finished PCB and I'm trying to add some features, but can't change the hardware, otherwise this problem will be very easy to solve, still don't know hoy can DT-Interrupts can be applied here
    Feb 2009
    Southern California
    Cool
    i don' know if your application will allow for it, but you can try adding polling throughout your code to have smaller wait times during the check and look for and use the wait command in serin2
    ... normal stuff
    gosub get_data
    ... more normal stuff
    gosub get_data
     more normal stuff
    get_data:
    serin2 Serial_IN, 84, 50, nodata, [wait (129), x]
    nodata:
    If you can adjust your transmitting device add a bunch of dummy spaces before the transmission so if you miss 1 or 2 no big deal, you weren't going to use them anyway. I''ve used something similar in the past.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
