Beginner having trouble with interrupt..
Results 1 to 11 of 11
    Oct 2008
    Smile Beginner having trouble with interrupt..
    Hello everyone,
    I'm trying to make a simple program that will blink a LED on PortB.2. While waits for an incoming character to PortC.7(with max232). My trouble I think is with the command serin PortC.7, T2400, RX and my PortB.2 doesnt blink. I appreciate any help/guide to understand how I can make this work.
    CLEAR
    include "modedefs.bas" 'include serout defines
    DEFINE OSC 20
    OPTION_REG=%10000101
    				;Bit 7=1 disable pull ups on PORTB
    				;Bit 5=0 selects timer mode
    				;Bit 2=1  }
    				;Bit 1=0  } sets Timer0 pre-scaler to 64
    				;Bit 0=1  }
    INTCON=%10100000	;Bit 7=1 Enables all unmasked interrupts
    				;Bit 5=1 Enables Timer0 overflow interrupt
    				;Bit 2 flag will be set on interrupt and has to be cleared
    				;in the interrupt routine.  It is set clear to start with.
    RX   var byte    ; holds incoming character
    symbol led1=PORTB.0
    symbol led2=PORTB.1
    i    var byte    ;counter
    Cnt  var byte
    TRISB   = %11110000	;sets the 3 output pins in the B port
    PORTB = %00000000	;sets all pins low in the B port
    TRISC = %10000000   ;Set portC.7 for  serial input
    ON INTERRUPT GOTO INTERUPTROUTINE
    MAINLOOP:
            High PORTB.2
            For i = 0 to 200
    	    	Pause 1
    		Next i
            Low PORTB.2
            For i = 0 to 200
    	        Pause 1
    		Next i
        IF Cnt=49 then
                led1=1-led1
                Cnt=0
          if Cnt=50 then
                led2=1-led2
                Cnt=0
    GOTO MAINLOOP	;end of loop
    DISABLE
    INTERUPTROUTINE:
       serin PortC.7, T2400, RX 'Receive menu
       Cnt = Rx
    ENDINTERRUPT:	;
    INTCON.2 = 0		;clears the interrupt flag.
    RESUME		;resume the main program
    ENABLE		;DISABLE and ENABLE must bracket the int routine
    mbox
    Hello mbox,
    are you sure your PIC has portC interrupts? Which PIC are you using? I guess my question is what is the source of the interrupt? The timer ? I do not see anything to trigger the interrupt.
    Oct 2008
    Hi joe,
    I'm using Pic16F877A, to be honest I'm trying to learn how to use Interrupt command and got stuck...
    regards,
    mbox
    With a prescaler of 64 at 20MHz, Timer0 will overflow in about 3.2mS. With your loop from 0 to 200, you're going to have to send a LOT of serial data before it can make it through your loop and toggle PORTB.2 off.
    Every 3.2mS it jumps to your SERIN interrupt routine. It's going to sit there until it receives a byte of data. So it's going to take a good while before making it through your first loop.
    And, you really don't know what the count in Timer0 is when you exit your interrupt routine, so you might want to clear Timer0 before exiting just in case.
    You can check to make sure your Timer0 interrupt is happening by commenting out the SERIN line, and toggling another LED in your interrupt routine.
    Something like this;
    DISABLE
    INTERUPTROUTINE:
       'serin PortB.3, T2400, RX 'Receive menu
       'Cnt = Rx
       TOGGLE PORTB.3
       TMR0=0           ;clear Timer0 before exit
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2008
    Question
    Hi Bruce,
    Thanks for the reply, I realized that when I used the code PortB.3, T2400, RX PortB.2 starts to blink. Is this mean that Portc.7 can not be used as my rx?
    thanks in advance,
    mbox
    No. I was just pointing out why your original code didn't work as you expected.
    It doesn't matter which pin you use for receiving serial data. You just need to understand why your original code isn't working as expected.
    Every 3.2mS or so your program jumps to the SERIN interrupt routine. And it just sits there until it receives a byte of data.
    This means it will take a very long time before your first loop can finish because it gets interrupted too often for your first loop to complete.
    -Bruce
    tech at rentron.com
  1. Can't ID interrupt source with this IntHandler??
  2. Very Trouble with 8722 Interrupt
    By smarino in forum mel PIC BASIC
    Last Post: - 5th March 2009, 10:48
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
