ADCON does not compile 16F628
Results 1 to 4 of 4
    mslaney's Avatar
    mslaney Guest
    Default ADCON does not compile 16F628
    Hi there,
    Maybe you've [seen this/done this/fixed this...]
    PIC16F628
    If I try to compile with ADCON:
    symbol priviously undefined ADCON0 and GO_DONE
    If I try without ADCON: syntax error
    There is no reference to adcon in the datasheet.
    CMCON does nothing for me either.
    If the ANx pins are powered up as comparators, how do I set them to analog inputs to read a pot? Yes, I made an honest attempt at the datasheet.
    CODE:
    'Read a POT on AN0
    'Code converted from F876 to F628 to test ICD with realtime input
    'DEFINES
    Define ADC_BITS 8
    define ADC_CLOCK 30
    define ADC_SAMPLEUS 50
    define OSC 4
    define ADCON1
    cmcon = %00000001
    'VARIABLES
    adval var byte
    v_in var byte
    Init:
    portb = $00
    trisb =$0
    v_in = porta.1
    trisa = %00000001
    trisb = %11111111
    loop:
    adcin v_in,adval 'Read channel 0 adval
    ledtst1:
    if adval > 5 then tst2
    portb = %00000001
    goto cont
    tst2:
    if adval > 10 then tst3
    portb = %00000011
    goto cont
    tst3:
    if adval > 20 then tst4
    portb = %00000111
    goto cont
    tst4:
    if adval > 40 then tst5
    portb = %00001111
    goto cont
    tst5:
    portb = %00011111
    cont:
    goto loop
    Unhappy
    there's a simple answer to this. There's no analog to digital converter in the PIC16F628. You have only analog comparator. Wich is a big difference. This is also why you have those error message. If you want some PIC with analog to digital converter you may use the following
    PIC16F877,876...
    PIC12F675,683
    PIC16F819
    and many others.
    BTW if you want to have a POT reading, there's a function called POT or RCTIME that allow to do something like this in addition of one capacitor. Inputs must be set to digital to perform those statements. CMCON=7
    See PBP manual or Melabs website for some code examples.
    New England
    Default Re: ADCON does not compile 16F628
    Hi Mike,
    As far as I remember the 16F628 does not have an ADC.
    It does have comparators - there is a fine tutorial by Melanie either here or on the PicBasic list about using the comparators (search function available at www.melabs.com).
    Arch
    mslaney's Avatar
    mslaney Guest
    Yes, you're right. I have mistaken pins RA0,1,2,3 / "AN0,1,2,3" for analog inputs rather than analog comparators. Doh!
    Thanks for the confirmation.
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 17:43
  2. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  3. Replies: 2
    Last Post: - 9th February 2006, 23:03
  4. 16F628 problems
    By fowardbias in forum mel PIC BASIC Pro
    Last Post: - 11th January 2006, 08:38
  5. SERIN2 not working with 16F628
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 6th May 2004, 21:37
