Servo and pwm
Results 1 to 11 of 11
Thread: Servo and pwm
    Oct 2006
    Edmonton AB Canada
    Default Servo and pwm
    Hi all,
    In reading the book (that should get me some spam in itself) I read that the PWM output wants an R/C network to "filter" the waveform. The burning question I've had, and now even worse, is that if the pic "wants" an R/C to give you nice clean PWM, why does the servo not work worth a dang when on the tail end of that R/C?
    Of course it would be much easier to answer the question if I'd just go buy a scope and watch that for a while.
    Has anybody watched these different outputs and can you tell me why the R/C is no go?
    Cheers
    Gary
    Meriachee, An R/C network attached to a pwm output will integrate the signal and turn it into an analog representation of the pwm value in percent between the full scale output voltage and 0. If you are talking about servos used for r/c control, most of them require a continuous series of pulses that are approx. 1.5 milliseconds wide and have a period of approx. 20 milliseconds.. The pulse width varies from about 1 millisecond to about 2 milliseconds. I think this is where you are getting confused....
    Oct 2006
    Edmonton AB Canada
    Thanks Dave,
    Analog makes sense.
    Cheers
    Gary
    Oct 2006
    Edmonton AB Canada
    The little servo I am using is moving the arm when the power comes up in a rather uncontrollable fashion, until the pic is operational. With the linkage I am using, eventually it will cause some issues.
    I am thinking about putting a 2n3904 on the ground leg of the servo and bring it up on a gpio, ensuring that the power is "off" until the pic is running and ready to go. Any ideas on this approach, or is there a better way to ensure the servo does not rotate at all until the pic is ready?
    Meriachee, Possibly a pass transistor in series with the power lead to the servo. After the pic is up and running w/pwm pulses to the servo, turn on the power to the servo. That is what I can come up with as a quick and dirty solution. All servos act like that upon powerup with no command signal that I have seen...
    May 2008
    Default Pic/servo startup
    Hmm. I haven't seen that servo behavior myself, but I thought it might be worth an experiment so I plugged a servo directly into a battery pack with no signal. One out of every ten or so times I plugged it in it would twitch just barely. Is that the issue you're having? If this is it I think you have to go with switched power but it is a very small movement and it might be related to the specific servo you're using.
    If not you might want to look at where and what value is associated with thethe first pulseout is in your code. I have had issues where the servo is moved far from a default position and startup includes significant movement as it heads for default and I've also set the default position at the wrong value and had movement. Finally I've had the pic come up with outputs high or not set until late in the program which gave me some issues.
    I've also on rare occasion had spurious signals from dirty power - might want to check that. I'm also assuming that you're posting about standard 1-2ms commanded hobby or robotics servos.
    Post
    Quote Originally Posted by Meriachee View Post
    Hi, Dave
    You CAN'T have your servo, if an "analogic" one, steady while powering on its amplifier ... that's it !!!
    The only way is to cut the power to the motor terminals ( relay ...)
    Solution is to use a DIGITAL servo which control circuitry won't drive the motor at Power-up.
    No simple solution for "old analogic" servos ...
  1. PMDC SERVO MOTOR WITH quadrature encoder DRIVE ?
    By phoenix_1 in forum Schematics
    Last Post: - 22nd November 2009, 20:45
  2. The best way to control a servo with a PIC
    Last Post: - 19th October 2008, 03:44
  3. how to change servo motor PWM
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 21st September 2008, 08:02
  4. RC Servo Receiver
    By Ioannis in forum General
    Last Post: - 23rd October 2007, 07:56
  5. inturrepts to control the servo motor position!
    By parinshah in forum mel PIC BASIC Pro
    Last Post: - 2nd May 2006, 08:55
