I try to build a box for cigarettes.
Parts:
-pic16F913
-mclr reset
-ext int (using DT interrups)
-dumb LCD
-h-bridge+latching solenoid
Unfortunately the LCD show me just "999"...and even the ext interrupts doesn`t work
If you guys have a minute just take a look...see the attachments
Thank you
 @        __config _INTOSCIO & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _BOD_OFF & _IESO_OFF  & _FCMEN_OFF & _CP_OFF & _CPD_OFF
CLEAR       'Clear all ram registers
'MCU CLOCK SOURCE
OSCCON.0 = 0       'int osc is used for sys clock (SCS bit)
OSCCON.6 = 0       'int osc freq 32kHz (IRCF bits)
OSCCON.5 = 0
OSCCON.4 = 0
'PORTS CONFIG
ANSEL=0                  'Analog to Digital converter disabled
TRISA = %10000000  'PORTA.7 (T1OSI=XTAL) to inputs
TRISB = %00000001  'PORTB.0 (=external interrupts) to input
TRISC = %00000111  'PORTC.2 to 0 (=1/3 BIAS for LCD) to inputs
''Timer1 CONFIGURATION (part of)
T1CON.1 = 1           'clock for Timer1 is ext (TMR1CS bit)
T1CON.2 = 1           'do not sync with the int clock (T1SYNC bit)
T1CON.3 = 1           'LP oscillator is enabled for Timer1 clock (when INTOSC without CLKO is active) (T1OSCEN bit)
'LCD CONFIGURATION
LCDCON.4 = 1         'enable bias voltage pins (VLCDEN bit)
LCDCON.3 = 1         'clock source LFINTOSC (31kHz/32) (CS bits)
'LCDCON.2 = ?
LCDCON.0 = 1        '1/4 multiplex (all COM used) (LMUX bits)
LCDCON.1 = 1
LCDPS.7 = 0         'waveform type-A (WFT bit)
LCDPS.6 = 0         'bias mode (when LMUX=11) (BIASMD bit)
LCDPS.3 = 0         '1:16 prescaler (31kHz/32/8=121Hz) (LP bits)
LCDPS.2 = 1
LCDPS.1 = 1
LCDPS.0 = 1
LCDSE0.3 = 1       'enable SEG3,4,5,6,8,9 (SE bits)
LCDSE0.4 = 1
LCDSE0.5 = 1
LCDSE0.6 = 1
LCDSE1.0 = 1
LCDSE1.1 = 1
'Clear??? LCDDATA registers see AN1070
LCDCON.6 = 0     'enable the LCD in SLEEP mode (SLPEN bit)
'PIR2.4 = 0         '(why ???) clear LCD Interrupt Flag (LCDIF bit)
'VARIABILES
adr4tmr1LO VAR BYTE     'RAM adr for startup timer1_LOW _BYTE value
adr4tmr1HI VAR BYTE     'for timer1_HIGH _BYTE value
T1 VAR WORD        'temp var for TMR1 startup value
nc var word
nc0 var word	'number of cigarettes (index) at address 0+1
nc2 var word	'at adr 2+3
nc4 var word	'at adr 4+5
LCD VAR WORD           'number on LCD
hundreds VAR BYTE     'temporary LCD var
tens var byte             'temp LCD var
ones var byte             'temp LCD var
INCLUDE "DT_INTS-14.bas"
INCLUDE "ReEnterPBP.bas"
INT_LIST  macro
     INT_Handler    INT_INT,  _open_battery_cover,   PBP,  yes
    INT_CREATE
    INT_ENABLE   INT_INT
'WRITE TO EEPROM the startup timer1 values DIVIDED by 4 to fit into the 14 bytes (Timer1_startup_value/4)
DATA @48,WORD 12773,WORD 12927,WORD 13080,WORD 13234,WORD 13388,WORD 13541,WORD 13695,WORD 13848
'...not completed...more then 10k characters to upload
'LATCH THE BOX
lock_the_box:
PORTB.1 = 1       'armature out
PAUSE 1
PORTB.1 = 0
'GET THE CIGARETTE INDEX
Interval_Tigari:
READ 0, NC0.LowByte    'read the last cigarette index from EEPROM_location 1
READ 1, NC0.HighByte    'from EEPROM_location 1
READ 2, NC2.LowByte    'from EEPROM_location 2
READ 3, NC2.HighByte    'from EEPROM_location 2
READ 4, NC4.LowByte    'from EEPROM_location 3
READ 5, NC4.HighByte    'from EEPROM_location 3
'IF power down at writing between (nc0.LowByte and nc0.HighByte) or (nc0 and nc2)
if nc4-nc2=0 then
    IF nc2-nc0<>0 THEN
        nc=nc2+1
        goto next_cigarette
'IF power down at writing between (nc2.LowByte and nc2.HighByte)
if nc4-nc2<>0 THEN
    IF nc2-nc0<>0 then
        nc=nc4+1
        goto next_cigarette
'IF power down (or not) at writing anywere else
nc=nc0
next_cigarette:
if nc = 16383 then         'EEPROM is just 14 bytes
    goto get_adr4tmr1
NC = NC+1       'next cigarette
'GET START RAM ADDRESS RANGE FOR TIMER1 STARTUP VALUE BY CIGARETTE INDEX
get_adr4tmr1:
SELECT CASE nc
    Case Is < 141       '1st week
        adr4tmr1lo=48
    Case Is < 255       '2nd week
        adr4tmr1lo=64
    Case Is < 349       '3rd week
        adr4tmr1lo=80
    Case Is < 430       '4th week
        adr4tmr1lo=96
    Case Is < 500       '5th week
        adr4tmr1lo=112
    Case Is < 563       '6th week
        adr4tmr1lo=128
    Case Is < 619       '7th week
        adr4tmr1lo=144
    Case Is < 670       '8th week
        adr4tmr1lo=160
    Case Is < 717       '9th week
        adr4tmr1lo=176
    Case Is < 760       '10th week
        adr4tmr1lo=192
    Case Is < 800       '11th week
        adr4tmr1lo=208
    Case Is < 837       '12th week
        adr4tmr1lo=224
    Case Is >=837       '13th week and more
        adr4tmr1lo=240
END SELECT
'COUNTDOWN LCD
Countdown:
LCDCON.7 = 1      'enable the LCD module (LCDEN bit)
for hundreds = 9 to 0 step -1
    LOOKUP hundreds,[1,0,1,1,0,1,1,1,1,1],LCDDATA10.1
    'hundreds seg A (0 to 9)
    for tens = 9 to 0 step -1
        LOOKUP TENS,[1,0,1,1,0,1,1,1,1,1],LCDDATA9.3
        'tens seg A (0 to 9)
        for ones = 9 to 0 step -1
            LOOKUP ones,[1,0,1,1,0,1,1,1,1,1],LCDDATA9.5 'ones seg A (0 to 9)
            LCD=hundreds*100+TENS*10+ONES
'GET START RAM ADDRESS FOR TIMER1 STARTUP VALUE BY LCD VALUE
                IF LCD<=999 THEN
                    IF LCD>=875 THEN
                       goto Start_Timer1_interrupt
                IF LCD<=874 THEN
                    IF LCD>=750 THEN
                        adr4tmr1lo = adr4tmr1lo+2
                IF LCD<=749 THEN
                    IF LCD>=625 THEN
                        adr4tmr1lo = adr4tmr1lo+4
                IF LCD<=624 THEN
                    IF LCD>=500 THEN
                        adr4tmr1lo = adr4tmr1lo+6
                IF LCD<=499 THEN
                    IF LCD>=375 THEN
                        adr4tmr1lo = adr4tmr1lo+8
                IF LCD<=374 THEN
                    IF LCD>=250 THEN
                        adr4tmr1lo = adr4tmr1lo+10
                IF LCD<=249 THEN
                    IF LCD>=125 THEN
                        adr4tmr1lo = adr4tmr1lo+12
                IF LCD<=124 THEN
                        adr4tmr1lo = adr4tmr1lo+14
Start_Timer1_Interrupt:
                READ adr4tmr1lo,T1.LowByte     'Timer1_startup_value/4
                adr4tmr1HI=adr4tmr1lo+1
                READ adr4tmr1HI,T1.HighByte
                T1 = T1*4          'Timer1 REAL startup value
                TMR1H = T1.HighByte
                TMR1L = T1.LowByte
                T1CON.0 = 1      'enable Timer1 (TMR1ON bit)
                T1CON.5 = 1      'Timer1 input clock prescale (1:8) (T1CKPS bits)
                T1CON.4 = 1
                T1CON.6 = 1      'enable Timer1 Gate (T1GE bit)
                T1CON.7 = 0      'Timer1 Gate is not inverted (T1GWN bit)
                PIE1.0 = 1         'enable overflow int (TMR1IE bit)
                INTCON.6 = 1     'enable all unmasked peripheral int (PEIE bit)
                INTCON.7 = 1     'enable global int (GIE bit)
@ sleep
@ nop
@ nop
                PIR1.0 = 0         'clear Timer1 int flag (TMR1IF bit)
                PIE1.0 = 0         'disable overflow int (TMR1IE bit)
                T1CON.0 = 0      'disable Timer1 (TMR1ON bit)
        next ones
    next tens
next hundreds
'UNLOCK THE BOX
unlock_the_box:
WHILE PORTB.0 = 1
'write to lcd OCE "open cover error"
WEND
PORTA.0 = 1                                 'armature in
PAUSE 1
PORTA.0 = 0
'write the same "nc" value at three locations to fix the power down issue at the writing time
WRITE 1, NC.HighByte      'write to RAM the "nc" LOW BYTE
WRITE 0, NC.LowByte      'the "nc" HIGH BYTE
WRITE 3, NC.HighByte
WRITE 2, NC.LowByte
WRITE 5, NC.HighByte
WRITE 4, NC.LowByte
'turn off the LCD
LCDCON.4 = 0    'disable bias voltage pins (VLCDEN bit)
LCDCON.6 = 1    'disable the LCD in SLEEP mode (SLPEN bit)
LCDCON.7 = 0    'disable the LCD module (LCDEN bit)
END                 'wait for MCLR reset
'INTERRUPT WHEN THE BATTERY COVER IS OPEN
open_battery_cover:
PAUSE 1
PORTB.1 = 0
@ INT_RETURN
Attachment 3357
Attachment 3358
