DS1820 with 16f688
Results 1 to 14 of 14
    jessey's Avatar
    jessey Guest
    Default DS1820 with 16f688
    Hello Everyone,
    I've been trying to get my DS1820 to work on my 16f688 and can't figure out why it won't display the proper temperature but the exact same code on my 16f877 works good. This code will only display 31 degrees F. Would anyone have any suggestions as to why it's not functioning properly? It's a real stumper for me and any help would be much appreciated.
    jessey
    '* Name    : Test Program for DS1820 & 4 x 20 LCD                                *
    '* Author  : Jessey Montgomery                                                   *
    '* Includes: Darrel Taylor's EE_Vars.PBP                                         *
    '* Date    : April 20/th 2009                                                    *
    '* Version : Using PicBasic Pro Ver 2.50, MPASM Ver 5.20, Using MicroCode Studio *
    '*         : 3.0.0.5, PICkit 2 programmer - Application Version 2.50.02 - Device *
    '*         : File Version 1.5100 - OS Firmware Version 2.30.01. Using a 16F688.  *
    '(1) Comments & Objectives
    ' this program is just a test program for checking out the new 4 x 20 lcd and
    ' also displaying temperature using a DS1820. This program communicates with a
    ' 16f877 to turn On/Off X10 appliance modules using a fireCracker.
    '                               |   16f688   |
    '                   VDD+ (--->) |1         14| (<---) VSS-
    '   RA5/TICKI/OSC1/CLKIN (<-->) |2         13| (<-->) RA0/AN0/C1IN+/ICSPDAT/ULPWU
    'RA4/AN3/TIG/OSC2/CLKOUT (<-->) |3         12| (<-->) RA1/AN1/C1IN-/Vref/ICSPCLK
    '            RA3/MCLR/Vpp(--->) |4         11| (<-->) RA2/AN2/TOCKI/INT/C1OUT
    '              RC5/RX/DX (<-->) |5         10| (<-->) RC0/AN4/C2IN+
    '        RC4/C2OUT/TX/CX (<-->) |6          9| (<-->) RC1/AN5/C2IN-
    '                RC3/AN7 (<-->) |7          8| (<-->) RC2/AN6
    '              Clear Each Port Before Setting The TRIS Registers
     Clear   ' Set all ram registers to zero
     PORTA = 0
     PORTC = 0
    '                            VSS VDD MCLR Ect. Pins
    'VDD +       '(pin 1)
    'VSS -       '(pin 14)
     '                    SET THE TRIS
     '                     PORTA PINS
     TRISA.0 = 0 '(pin 13) ............................Out_To_877_Pin_37 VAR PORTA.0
     TRISA.1 = 0 '(pin 12) ............................Out_To_877_Pin_38 VAR PORTA.1
     TRISA.2 = 0 '(pin 11) ............................Out_To_877_Pin_39 VAR PORTA.2
     TRISA.3 = 1 '(pin 4)  .......................................... DQ VAR PORTA.3
     TRISA.4 = 0 '(pin 3)  ..........................................Led VAR PORTA.4
     TRISA.5 = 1 '(pin 2)  .................................... Button_5 VAR PORTA.5
     '                     PORTC PINS
     TRISC.0 = 0 '(pin 10) Blue........... Lcd Data bit 4
     TRISC.1 = 0 '(pin 9)  White.......... Lcd Data bit 5
     TRISC.2 = 0 '(pin 8)  Green.......... Lcd Data bit 6
     TRISC.3 = 0 '(pin 7)  Orange......... Lcd Data bit 7
     TRISC.4 = 0 '(pin 6)  Orange/Black... Lcd Register select
     TRISC.5 = 0 '(pin 5)  Blue/White..... Lcd Enable bit
    '(2) PIC Config Fuse Definitions for 16f688
     @ __CONFIG _INTOSCIO & _WDT_ON & _MCLRE_OFF & _CP_OFF
     @ ERRORLEVEL -306; ' turns off cross page boundary message alerts
    '(3) PIC Hardware Definitions (ie Pin-Out & Port Assignments)
     ANSEL = 0
     CMCON0 = 7         ' turn off comparators
     DEFINE LCD_RSREG PORTC' LCD Register Select Port
     DEFINE LCD_RSBIT 4    ' LCD Register Select
     DEFINE LCD_EREG PORTC ' LCD Enable Port
     DEFINE LCD_EBIT 5     ' LCD Enable
     DEFINE LCD_DREG PORTC ' LCD Data Port
     DEFINE LCD_DBIT 0     ' LCD data starting bit 0 or 4
     Out_To_877_Pin_37 VAR PORTA.0 ' pin 13
     Out_To_877_Pin_38 VAR PORTA.1 ' pin 12
     Out_To_877_Pin_39 VAR PORTA.2 ' pin 11
     Button_5 VAR PORTA.5          ' pin 2
     Led VAR PORTA.4               ' pin 3
     a VAR BIT ' a always equals zero, used in IF-THEN's instead of using GOTO's
     a = 0
     Timer VAR byte
     Timer = 0
     temp VAR	WORD          ' Temperature storage
     count_remain VAR BYTE    ' Count remaining
     count_per_c VAR	BYTE  ' Count per degree C
     Sign  VAR  BIT           ' bit determines id - sign is needed
     DQ VAR PORTA.3           ' One-wire data pin (pin 4)
     Is_Pressed CON 0
     Is_Not_Pressed CON 1
     Is_Turned_On CON 1
     Is_Turned_Off CON 0
    '4a. EEPROM Assignments
     INCLUDE "EE_Vars.PBP"
    '        'Declare The EE Variable' 'Load A Default Setting For The EE Variable'
                         X  VAR  BYTE : @  EE_var  _X, BYTE,0
                         Y  VAR  BYTE : @  EE_var  _Y, BYTE,0
                         Z  VAR  BYTE : @  EE_var  _Z, BYTE,0
    '         To write to the eeprom   @  EE_write_var  _X
    ' Reset all three PORT outputs to the states they were before the power-loss
     IF X = 1 THEN
        Out_To_877_Pin_37 = 1
     ELSE '                  PORTA.0 pin 13
        Out_To_877_Pin_37 = 0
     IF Y = 1 THEN ' pin 12
        Out_To_877_Pin_38 = 1
     ELSE '                  PORTA.1 pin 12
        Out_To_877_Pin_38 = 0
     IF Z = 1 THEN 'pin 11
        Out_To_877_Pin_39 = 1
     ELSE '                  PORTA.2 pin 11
        Out_To_877_Pin_39 = 0
     Led = Is_Turned_Off
     LCDOUT  254,64,14,10,14,0,0,0,0,0 ' Cust Char #0 - degree sign
     PAUSE 500 ' For LCD
    IF a = 0 THEN MainLoop ' a always equals zero, use instead of GOTO...
    Turn_On_Or_Off_3:
        if Y = 0 then ' Y toggles the #3 X10 module On/Off with each button press
           Y = 1      ' Turn On #3 X10 module
           Y = 0      ' Turn Off #3 X10 module
        @  EE_write_var  _Y ' remember Y in case of a power failure
        IF Y = 0 THEN Out_To_877_Pin_38 = 0 ' #3 X10 module is Off
        if Y = 1 then Out_To_877_Pin_38 = 1 ' #3 X10 module is On
    Turn_On_Or_Off_4:
        if X = 0 then ' X toggles the #4 X10 module On/Off with each button press
           X = 1      ' Turn On #4 X10 module
           X = 0      ' Turn Off #4 X10 module
        @  EE_write_var  _X ' remember X in case of a power failure
        IF X = 0 THEN Out_To_877_Pin_37 = 0 ' #4 X10 module is Off
        if X = 1 then Out_To_877_Pin_37 = 1 ' #4 X10 module is On
    Turn_On_Or_Off_5:
        if Z = 0 then ' Z toggles the #5 X10 module On/Off with each button press
           Z = 1      ' Turn On #5 X10 module
           Z = 0      ' Turn Off #5 X10 module
        @  EE_write_var  _Z ' remember Z in case of a power failure
        IF Z = 0 THEN Out_To_877_Pin_39 = 0 ' #5 X10 module is Off
        if Z = 1 then Out_To_877_Pin_39 = 1 ' #5 X10 module is On
    Check_Temperature:
      OWOut DQ, 1, [$CC, $44]    ' Start Temp conversion
     waitloop:
      OWIn DQ, 4, [count_remain]	' Check for still busy converting
    	IF count_remain = 0 THEN waitloop
    	OWOut DQ, 1, [$CC, $BE]		  ' Read the Temp
      OWIn DQ, 0, [temp.LOWBYTE, temp.HIGHBYTE, _
                            Skip 4, count_remain, count_per_c]
        ' Calculate temp in degrees Celsius to 2 decimal places
         Sign = temp.15
         temp = ((ABS(temp) >> 1) * 100)
         if Sign then temp = -temp
         temp = temp - 25 _
                         + (((count_per_c - count_remain) * 100) / count_per_c)
        ' Convert Celsius to Fahrenheit before returning
         Sign = temp.15
         temp = (ABS(temp) */ 461)
         temp = temp + 3200
    MainLoop:
     GOSUB Check_Temperature
     IF Button_5 = Is_Pressed THEN
       Timer = 0
       WHILE Button_5 = Is_Pressed
         Led = Is_Turned_On
         Timer = Timer + 1
         IF Timer = 4 THEN Timer = 1
         lcdout $fe, 1, "Release Sw When ? #",DEC Timer
         LCDOut $fe, $c0, "If # = 1 then X10-3 "
         lcdout $fe,$94, "If # = 2 then X10-4 "
         lcdout $fe,$d4,"If # = 3 then X10-5 "
         PAUSE 1000
       WEND
       Led = Is_Turned_Off
       PAUSE 100 ' Debounce Push Button
       IF Timer = 1 THEN GOSUB Turn_On_Or_Off_3
       IF Timer = 2 THEN GOSUB Turn_On_Or_Off_4
       IF Timer = 3 THEN GOSUB Turn_On_Or_Off_5
      LCDOut $fe, 1, "X10Temp Demo Program"
      LCDOut $fe, $c0," Jessey Montgomery  "
      lcdout $fe,$94,"#3 = ",DEC Out_To_877_Pin_38, _
                     " #4 = ",DEC Out_To_877_Pin_37," #5 = ",DEC Out_To_877_Pin_39
      lcdout $fe,$d4
      LCDOut "  Temp = "
      if temp.15 = 1 then LCDOut "-"
      temp = ABS(temp)
      LCDOut DEC temp / 100,0
      LCDOut "F   "
      Pause 100
    Hi Jessey,
    On the 16F688, RA3 is Input Only when MCLR is disabled.
    The Pin needs to have output capability to talk to a DS1820.
    hth,
    jessey's Avatar
    jessey Guest
    Default Much appreciated Darrel
    Hi Darrel,
    I didn't realize that, thanks for the heads up. That might also explain why I couldn't get my FireCracker code to work on the 688 a while back.
    Thanks Again
    jessey
    jessey's Avatar
    jessey Guest
    Default EE_Vars.PBP error with firecracker code
    Hi Darrel,
    When I try and compile the firecracker code below using your EE_Vars.PBP I get an error saying:
    " 3.asm 141: Overwriting previous address contents (2100) "
    I'd sure like to be able to use your EE_Vars.PBP because it has some neat features and is really easy to implement. Possibly the reason it won't compile has something to do with declaring the Data statements for the firecracker taking up some of the same address's as EE_Vars.PBP is using? I tried using EEPROMData100 var BYTE for X and EEPROMData101 var BYTE for Y and EEPROMData102 var BYTE for Z and it seems to be working good but I like your EE_Vars way better.
    Also the firecracker code won't work on the 16f688 when I do get it to compile without using your EE_Vars.PBP but the exact same code works perfectly on my 16f877 without your EE_Vars.PBP? I'll try changing the dtr & rts port pins but I can't really see them causing a problem. Any help would really be appreciated.
    jessey
    '* Name    : Test Program for the Firecracker Interface                        *
    '* Includes: Darrel Taylor's EE_Vars.PBP & Al Williams Firecracker Interface   *
    '* Date    : April 24/th 2009                                                  *
    '* Version : Using PicBasic Pro Ver 2.50, MPASM Ver 5.20, Using MicroCode      *
    '*         : Studio 3.0.0.5, PICkit 2 programmer - Application Version         *
    '*         : 2.50.02 - Device File Version 1.5100 - OS Firmware Version        *
    '*         : 2.30.01. Using a Pic16F688-I/P 04470AY.                           *
    ' this program is just a test program for checking the firecracker
     PORTA = 0
     PORTC = 0
     'VDD +       '(pin 1)
     'VSS -       '(pin 14)
     '                    SET THE TRIS
     '                     PORTA PINS
     TRISA.0 = 0 '(pin 13) connect green wire of firecracker - dtr VAR PORTA.0
     TRISA.1 = 0 '(pin 12) connect red wire of firecracker - rts VAR PORTA.1
     TRISA.2 = 0 '(pin 11) Not Used VAR PORTA.2
     TRISA.3 = 1 '(pin 4)  Button_5 VAR PORTA.3
     TRISA.4 = 0 '(pin 3)  Not Used VAR PORTA.4
     TRISA.5 = 0 '(pin 2)  Led VAR PORTA.5
     '                     PORTC PINS
     TRISC.0 = 0 '(pin 10) Blue Lcd Data bit 4
     TRISC.1 = 0 '(pin 9)  White Lcd Data bit 5
     TRISC.2 = 0 '(pin 8)  Green Lcd Data bit 6
     TRISC.3 = 0 '(pin 7)  Orange Lcd Data bit 7
     TRISC.4 = 0 '(pin 6)  Orange/Black Lcd Register select
     TRISC.5 = 0 '(pin 5)  Blue/White Lcd Enable bit
     @ ERRORLEVEL -306; ' turns off cross page boundary message alerts after compile
     ANSEL = 0          ' all pins are digital
      ' Data for house and unit codes
     housetbl data $60,$70,$40,$50,$80,$90,$A0,$B0,$E0,$F0,$C0,$D0
              data $00,$10,$20,$30
      unittbl data 0,$10,$8,$18,$40,$50,$48,$58
     Button_5 VAR PORTA.3 ' pin 4
     Led VAR PORTA.5      ' pin 2
     ' The 3 connections to the firecracker are below...
     ' Wire Ground (DB9 pin 5) black
     dtr VAR PORTA.0 ' pin 13 connects to DB9 pin 7 of the firecracker (green wire)
     rts VAR PORTA.1 ' pin 12 connects to DB9 pin 4 of the firecracker (red wire)
     a VAR BIT
     a = 0
     X VAR BYTE
     X = 0
     Y VAR BYTE
     Y = 0
     Z VAR BYTE
     Z = 0
     Timer VAR byte
     Timer = 0
    ' byte to send
     byt var byte
     tmp var byte
     i var BYTE 'was a nib
     state var bit(4)
     house var byte '0=A 1=B...
     unit var BYTE  ' 0-15  (must be 0 for bright/dim) 'was a nib
     cmd var BYTE  ' 0=off 1=on 2=bright 3=dim 'was a nib
     Is_Pressed CON 0
     Is_Turned_On CON 1
     Is_Turned_Off CON 0
     ' The Firecracker header (2 bytes)
     h1 con $D5
     h2 con $AA
     ' the Firecracker footer (1 byte)
     foot con $AD
    ' INCLUDE "EE_Vars.PBP"
    '           Declare The EE Variable - Load A Default Setting For The EE Variable
    '                     X  VAR  BYTE ': @  EE_var  _X, BYTE,0
    '                     Y  VAR  BYTE ': @  EE_var  _Y, BYTE,0
    '                     Z  VAR  BYTE ': @  EE_var  _Z, BYTE,0
    '                                  @  EE_write_var  _Y
    '                                  @  EE_write_var  _Z
     gosub resetfirecracker
     IF X = 1 THEN
        house = 0 : unit = 4 : cmd = 1 'when unit = 4 in code, set X10 receiver to 5
        gosub sendcmd
        house = 0 : unit = 4 : cmd = 0 'when unit = 4 in code, set X10 receiver to 5
        gosub sendcmd
     IF Y = 1 THEN
        house = 0 : unit = 2 : cmd = 1 'when unit = 2 in code, set X10 receiver to 3
        gosub sendcmd
        house = 0 : unit = 2 : cmd = 0 'when unit = 2 in code, set X10 receiver to 3
        gosub sendcmd
     IF Z = 1 THEN
        house = 0 : unit = 3 : cmd = 1 'when unit = 3 in code, set X10 receiver to 4
        gosub sendcmd
        house = 0 : unit = 3 : cmd = 0 'when unit = 3 in code, set X10 receiver to 4
        gosub sendcmd
     Led = Is_Turned_Off
     PAUSE 500 ' For LCD
    ' Firecracker Interface (Al Williams)
    ' http://www.awce.com/firecracker.htm or  http://www.al-williams.com/awce
    sendcmd:
      byt=h1
      gosub sendbyte
      byt=h2
      gosub sendbyte
      read housetbl+house,byt
      if unit<9 then lowunit
      byt=byt+4
    lowunit:
      gosub sendbyte
      byt=$20
      if cmd=0 then addunit
      byt=0
      if cmd=1 then addunit
      byt=$88
      if cmd=2 then nounit
      byt=$98
      if cmd=3 then nounit
    ' huh???
    addunit:
      read unittbl+(unit//8),tmp
      byt=byt+tmp
    nounit:
      gosub sendbyte
      byt=foot
      gosub sendbyte
    ' Send 1 raw byte
    sendbyte:
      debug hex byt," "
      for i=0 to 7
       if (byt & $80) = $80 then xmit1
       gosub send0
    nextbit:
       pause 1
       byt=byt*2
       next
    ' Send a 1
    xmit1:
      gosub send1
      IF a = 0 THEN nextbit
    ' Send bits (0 or 1)
    send0:
      low rts
      pause 1
      high rts
    send1:
      low dtr
      pause 1
      high dtr
    'Reset firecracker first
    resetfirecracker:
     low rts
     low dtr
     pause 50
     high rts
     high dtr
     pause 50
    Turn_On_Or_Off_4:
           X = 1      ' Turn On #5 X10 module
           house = 0 : unit = 4 : cmd = 1 'when unit=4 in code,set X10 receiver to 5
           gosub sendcmd : pause 1000
           X = 0      ' Turn Off #5 X10 module
           house = 0 : unit = 4 : cmd = 0 'when unit=4 in code,set X10 receiver to 5
    '    @  EE_write_var  _X ' remember X in case of a power failure
    Turn_On_Or_Off_3:
           house = 0 : unit = 2 : cmd = 1 'when unit=2 in code,set X10 receiver to 3
           house = 0 : unit = 2 : cmd = 0 'when unit=2 in code,set X10 receiver to 3
    '    @  EE_write_var  _Y ' remember Y in case of a power failure
    Turn_On_Or_Off_5:
        if Z = 0 then ' Z toggles the #4 X10 module On/Off with each button press
           Z = 1      ' Turn On #4 X10 module
           house = 0 : unit = 3 : cmd = 1 'when unit=3 in code,set X10 receiver to 4
           Z = 0      ' Turn Off #4 X10 module
           house = 0 : unit = 3 : cmd = 0 'when unit=3 in code,set X10 receiver to 4
    '    @  EE_write_var  _Z ' remember Z in case of a power failure
    MainLoop:
       Timer = 0
         Led = Is_Turned_On
         Timer = Timer + 1
         PAUSE 1000
       WEND
       Led = Is_Turned_Off
      LCDOut $fe, 1, "X10 FireCracker Demo"
      lcdout $fe,$94,"#3 = ",DEC Y, _
                     " #4 = ",DEC X," #5 = ",DEC Z
      Pause 100
    Quote Originally Posted by jessey View Post
    ... Possibly the reason it won't compile has something to do with declaring the Data statements for the firecracker taking up some of the same address's as EE_Vars.PBP is using?
    Yup, I think that's it too.
    $2100 is the first physical address in EEPROM.
    When you housetbl data $60, ..., it stores data at location 0. But it's really at 2100h.
    So does EEPROM EE_Start, [0]
    Both your program and EE_Vars are trying to define the same location in EEPROM.
    If you open the EE_Vars.pbp file ...
    The first line is ...
    EE_start         CON  0              ; Starting address for EE_Vars
    Change that to somewhere past the locations used for the existing data.
    Then they shouldn't conflict anymore.
    Or you can comment that line, and copy it to your main program. That'll keep it from using the wrong location the next time you use the include file.
    As for the firecracker not working.
    All those EEPROM locations would have been overwritten by EE_Vars.
    If they don't overlap, that won't happen.
    jessey's Avatar
    jessey Guest
    Hi Darrel,
    I opened EE_Vars.PBP in MicroCodeStudio and changed the CON 0 TO CON 91 then saved the file and closed it. Then I compiled the firecracker code with the INCLUDE "EE_Vars.PBP" which compiled fine. I then programmed the code into the 688 and although the X, Y and Z variables are being saved when power is removed and re-applied to the circuit the firecracker code still isn't communicating with the firecracker transmitter and the X10 modules still won't turn On/Off?
    Also, I tried commenting out the first line in EE_Vars.PBP then pasted it into my program with the starting address set to 91 as you suggested and when I try to compile I get an " ERROR Line 24: Redefinition of CON EE_start.(EE_Vars.PBP) ".
    I'll try programming a new 688 micro tomorrow, could it be that my eeprom is corrupted now?
    jessey
    jessey's Avatar
    jessey Guest
    Hi Darrel,
    I tried programming a new chip with ee_vars.pbp and I got the same results as before but I got the firecracker code working good using the saving routines below:
    EEPROMData91 var BYTE
    X VAR EEPROMData91
    READ 91, EEPROMData91
    '' To write to the eprom
    'EEPROMData91 = X
    'Write 91, EEPROMData91
    EEPROMData92 var BYTE
    Y VAR EEPROMData92
    READ 92, EEPROMData92
    'EEPROMData92 = Y
    'Write 92, EEPROMData92
    EEPROMData93 var BYTE
    Z VAR EEPROMData93
    READ 93, EEPROMData93
    'EEPROMData93 = Z
    'Write 93, EEPROMData93
    I tried changing the starting address in EE_Vars.pbp from CON 0 to CON 91 and although it compiles it doesn't work but when I comment out your eeprom saving routine and use the program below, the X10 code turns On and Off the X10 appliance modules and saving to the eeprom works like a charm.
    As I mentioned in my previous post, when I comment out the con 0 in EE_Vars.pbp and include it in my program as con 91 I get " ERROR Line 24: Redefinition of CON EE_start.(EE_Vars.PBP) " when I try to compile.
    It was only a guess on my part that the firecracker code was using some of the same address's as EE_Vars.PBP was using. I still don't quite understand mathematically how the address's of the various eeprom and other registry locations work using the Decimal, Hex and Binary number Systems. I should have stayed in school instead of being a juvenile delinquent then this would be a lot easier but I guess it's better late than never to get a little savy and this is interesting! Any ideas on what's happening with this?
    jessey
    '* Includes: Al Williams Firecracker Interface
     PORTA = 0
     PORTC = 0
     '                            VSS VDD Pins
     'VDD +       '(pin 1)
     'VSS -       '(pin 14)
     '                    SET THE TRIS
     '                     PORTA PINS
     TRISA.0 = 0 '(pin 13) Not Used VAR PORTA.0
     TRISA.1 = 0 '(pin 12) ..........................................Led VAR PORTA.1
     TRISA.2 = 1 '(pin 11) ..................................Push_Button VAR PORTA.2
     TRISA.3 = 0 '(pin 4)  Not Used VAR PORTA.3
     TRISA.4 = 0 '(pin 3)  .....connect to red wire of firecracker - dtr VAR PORTA.4
     TRISA.5 = 0 '(pin 2)  ...connect to green wire of firecracker - rts VAR PORTA.5
     '                     PORTC PINS
     TRISC.0 = 0 '(pin 10) Not Used VAR PORTC.0
     TRISC.1 = 0 '(pin 9)  Not Used VAR PORTC.1
     TRISC.2 = 0 '(pin 8)  Not Used VAR PORTC.2
     TRISC.3 = 0 '(pin 7)  Not Used VAR PORTC.3
     TRISC.4 = 0 '(pin 6)  Not Used VAR PORTC.4
     TRISC.5 = 0 '(pin 5)  Not Used VAR PORTC.5
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF & _BOD_ON
    @ ERRORLEVEL -306;
     OSCCON.3 = 1       ' Use internal clock
     OSCCON = %1110111  ' Use Internal OSC at 8MHz
     Push_Button VAR PORTA.2 ' pin 11
     Led var PORTA.1         ' pin 12
     rts VAR PORTA.5 ' pin 2 connects to DB9 pin 4 of the firecracker (green wire)
     dtr VAR PORTA.4 ' pin 3 connects to DB9 pin 7 of the firecracker (red wire)
     a VAR BYTE
     a = 0
     Timer VAR byte
     Timer = 0
    ' byte to send
     byt var byte
     tmp var byte
     state var bit(4)
     Is_Pressed CON 0
     Is_Turned_On CON 1
     Is_Turned_Off CON 0
     h1 con $D5
     h2 con $AA
     foot con $AD
    X VAR EEPROMData91
    'EEPROMData91 = X
    Y VAR EEPROMData92
    'EEPROMData92 = Y
    Z VAR EEPROMData93
    'EEPROMData93 = Z
    ' Reset the three X10 modules to the states they were before the power-loss
     IF X = 1 THEN
        gosub sendcmd : PAUSE 1000
     IF Y = 1 THEN
     IF Z = 1 THEN
     Led = Is_Turned_On
     PAUSE 200
     Led = Is_Turned_Off
    ' Start Of Subroutines Area Below
    ' Firecracker Interface by (Al Williams)
    sendcmd:
      byt=h1
      gosub sendbyte
      byt=h2
      gosub sendbyte
      byt=byt+4
    lowunit:
      gosub sendbyte
      byt=$20
      byt=0
      byt=$88
      byt=$98
    ' huh???
    addunit:
      byt=byt+tmp
    nounit:
      gosub sendbyte
      byt=foot
      gosub sendbyte
    ' Send 1 raw byte
    sendbyte:
      debug hex byt," "
      for i=0 to 7
       gosub send0
    nextbit:
       pause 1
       byt=byt*2
       next
    ' Send a 1
    xmit1:
      gosub send1
    send0:
      low rts
      pause 1
      high rts
    send1:
      low dtr
      pause 1
      high dtr
    ' Always reset firecracker first
    resetfirecracker:
    low rts
    low dtr
    pause 50  ' reset
    high rts
    high dtr
    pause 50
    Turn_On_Or_Off_4:
        if X = 0 then ' X toggles the #4 X10 module On/or/Off with each button press
           X = 1      ' Turn On
           gosub sendcmd
           X = 0      ' Turn Off
           gosub sendcmd
        EEPROMData91 = X
    '@  EE_write_var  _X
    Turn_On_Or_Off_3:
        if Y = 0 then ' Y toggles the #3 X10 module On/or/Off with each button press
           Y = 1      ' Turn On
           gosub sendcmd
           Y = 0      ' Turn Off
           gosub sendcmd
        EEPROMData92 = Y
    '@  EE_write_var  _Y
    Turn_On_Or_Off_5:
        if Z = 0 then ' Z toggles the #4 X10 module On/or/Off with each button press
           Z = 1      ' Turn On
           gosub sendcmd
           Z = 0      ' Turn Off
           gosub sendcmd
        EEPROMData93 = Z
    '@  EE_write_var  _Z
    'XXXXXXXXXXX'
    MainLoop:
     IF Push_Button = Is_Pressed THEN
       Timer = 0
       WHILE Push_Button = Is_Pressed
         Timer = Timer + 1
         IF Timer = 1 THEN Led = Is_Turned_On
         IF Timer = 2 THEN Led = Is_Turned_Off
         IF Timer = 3 THEN Led = Is_Turned_On
         IF Timer = 4 THEN Led = Is_Turned_Off
         IF Timer = 5 THEN Led = Is_Turned_On
         IF Timer = 6 THEN Led = Is_Turned_Off
         PAUSE 500
       WEND
         Led = Is_Turned_Off
         IF Timer = 2 THEN GOSUB Turn_On_Or_Off_3
         IF Timer = 3 THEN GOSUB Turn_On_Or_Off_4
         IF Timer = 4 THEN GOSUB Turn_On_Or_Off_4
         IF Timer = 5 THEN GOSUB Turn_On_Or_Off_5
         IF Timer >= 6 THEN GOSUB Turn_On_Or_Off_5
  1. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 13:12
  2. PIC lcd ds1820
    By wchpikus in forum mel PIC BASIC
    Last Post: - 24th May 2007, 14:46
  3. Help with 16f688
    Last Post: - 20th October 2006, 23:12
  4. DS1820 again
    By paxmowa in forum mel PIC BASIC Pro
    Last Post: - 10th January 2006, 14:49
  5. Problem with 16F688 and Hserout
    By DWV in forum mel PIC BASIC Pro
    Last Post: - 19th March 2005, 05:37
