Try replacing the dots by underscores in the variable names like I show you below. I used underscores all the time. I don't think you can use dots in variable names.
Switch_0 VAR PortA.0
Switch_1 VAR PortA.1
Or
SWITCH var PortA
then
SWITCH.0
SWITCH.1
SWITCH.2
are valid names of each Bit/Port
or this way
switch var byte
switch.0 = portA.0
switch.1 = portA.1
Thanks for the suggestions. What worked well is the first sugggestion,
Switch_0 var Porta.0
Switch_1 var PortA.1
Now I can access the contents of the two switches through Switch.
Thanks again...Chris
Chris Shatara
