Have you tried switching this;
To this;Code:SWITCH: IF setting=1 THEN 'if setting is 1, write 2 to EEPROM WRITE 1,%00000010 ENDIF IF setting=2 THEN 'if setting is 2, write 1 to EEPROM WRITE 1,%00000001 ENDIF
Code:SWITCH: IF setting=1 THEN 'if setting is 1, write 1 to EEPROM WRITE 1,%00000001 ENDIF IF setting=2 THEN 'if setting is 2, write 2 to EEPROM WRITE 1,%00000010 ENDIF
