EEPROM Memory
Results 1 to 4 of 4
Thread: EEPROM Memory
    Feb 2009
    Southern California
    I've been looking over your code for about 10 minutes and nothing is jumping out at me. My only thought is something flaky is going on during the power down stage where PORTB.4 goes high momentarily. You could try adding a debounce or a small pause at the beginning of the SWITCH routine and see if there is any change.
    David
    Jun 2008
    Just tried that, didn't seem to make much difference...It toggled a bit smoother though.
    My guess is somehow the program is causing the EEPROM value to switch at startup or shutdown. No clue how though.
    Thank you,
    Matt
    Have you tried switching this;
    SWITCH:
    IF setting=1 THEN 'if setting is 1, write 2 to EEPROM
    WRITE 1,%00000010
    IF setting=2 THEN 'if setting is 2, write 1 to EEPROM
    WRITE 1,%00000001
    To this;
    SWITCH:
    IF setting=1 THEN 'if setting is 1, write 1 to EEPROM
    WRITE 1,%00000001
    IF setting=2 THEN 'if setting is 2, write 2 to EEPROM
    WRITE 1,%00000010
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
