EEPROM Memory
Results 1 to 4 of 4
Thread: EEPROM Memory
    Jun 2008
    Default EEPROM Memory
    I am toying around with a Lab X1 board, trying to make a program that turns on one of two LEDs, (toggled by a switch), then remembers which LED is on when I reset the power. Right now, it always turns on the opposite of the light the was on before I turned it off. Though this does satisfy my goal of using stored memory after power is turned off, I would like it to turn on the correct light, instead of the opposite on, and for the life of me, I can't figure out why. I am sure it is something simple that I am just missing.
    If anyone could take a quick look at my code, it would be phenomenal.
    Matt
    EEPROM 1,[%00000001] 'set initial EEPROM Value
    TRISB=%11110000 'set imputs and outputs
    PORTB=%11111110
    OPTION_REG.7=0
    setting Var BYTE 'declare setting as a variable
    READ 1,setting 'read EEPROM value to setting
    PAUSE 100
    LOOP:
    IF setting=%00000001 THEN 'determines which LED to turn on
    HIGH PORTD.0
    LOW PORTD.1
    IF setting=%00000010 THEN
    LOW PORTD.0
    HIGH PORTD.1
    IF PORTB.4=1 THEN 'goto subroutine on button press
    GOSUB SWITCH
    GOTO LOOP
    SWITCH:
    IF setting=1 THEN 'if setting is 1, write 2 to EEPROM
    WRITE 1,%00000010
    IF setting=2 THEN 'if setting is 2, write 1 to EEPROM
    WRITE 1,%00000001
    WHILE PORTB.4=1 'wait for button release
    PAUSEus 10
    WEND
    RETURN 'go back to main loop
    Feb 2009
    Southern California
    I've been looking over your code for about 10 minutes and nothing is jumping out at me. My only thought is something flaky is going on during the power down stage where PORTB.4 goes high momentarily. You could try adding a debounce or a small pause at the beginning of the SWITCH routine and see if there is any change.
    David
    Jun 2008
    Just tried that, didn't seem to make much difference...It toggled a bit smoother though.
    My guess is somehow the program is causing the EEPROM value to switch at startup or shutdown. No clue how though.
    Thank you,
    Matt
    Have you tried switching this;
    SWITCH:
    WRITE 1,%00000010
    WRITE 1,%00000001
    To this;
    SWITCH:
    IF setting=1 THEN 'if setting is 1, write 1 to EEPROM
    WRITE 1,%00000001
    IF setting=2 THEN 'if setting is 2, write 2 to EEPROM
    WRITE 1,%00000010
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 15:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 04:17
  3. Replies: 4
    Last Post: - 2nd March 2007, 07:12
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 07:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
