Welcome into PIC world
Results 1 to 25 of 25
    Apr 2009
    Default Thanks for your reply
    Hi one of the document says the VSS should be connected to the middle pin of resonator, thats why it was connected to Vss and the pullup resistor i have used for MCLR is 4.7K. the other end of pullup resistor the voltage was around 2+_ volts.
    As you said today let me try by connecting the resonator middle pin to Ground , i will post you the output later.
    Hello Syed,
    I am looking at the picture you posted, you have a wire going from the center of the resonator to pin 5 of the PIC but no wire from Pin 5 to ground. It must be grounded to the 5v supply, otherwise the PIC receives no power.
    Hello Syed,
    See Attachment:
    <img src=>http://www.picbasic.co.uk/forum/atta...1&d=1240594618
    Apr 2009
    Unhappy Bad luck
    Hi Guys,
    Bad luck i tried changing another Pic16f84a
    no work, i tried with multiple resonators and 4mhs with 47 / 10 pf that also doesnt' work.
    here is the code file in two formats, probably i will update my cirucit picture tomorrow.
    Code :
    @ DEVICE pic16F84A
    define OSC 4
    TrisB = %00000000
    loop:
    High PORTB.0 ' Turn on LED connected to PORTB.0
    Pause 1000 ' Delay for .5 seconds
    Low PORTB.0 ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    and in Hex:
    0000- 2828 018f 008e 30ff 078e 1c03 078f 1c03
    0008- 2823 3003 008d 30df 200f 2803 018d 3ee8
    0010- 008c 098d 30fc 1c03 2818 078c 1803 2815
    0018- 078c 0064 0f8d 2815 180c 281e 1c8c 2822
    0020- 0000 2822 0008 1383 1303 1283 0064 0008
    0028- 1683 0186 1283 1406 1683 1006 1283 3003
    0030- 008f 30e8 2002 1006 1683 1006 1283 3003
    0038- 008f 30e8 2002 282b 0063 283c
    I noticed when i take off the Vss pin then the led is constantly lighting up.
    if i connect Vss then nothing comes up. no power in the pins . with the multimeter i checked the pullup capacitor
    is giving me 1.24 reading and no power on the pins,
    what would be the problem. Is there any way of tracing this where it is going wrong?
    Hi Syed,
    Try this code:
    @ DEVICE pic16F84A
    define OSC 4
    PortB = 0 ' set port latches low
    TrisB = %00000000 ' set portb as outputs
    loop:
    PORTB.0 = 1' Turn on LED connected to PORTB.0
    PORTB.0 = 0 ' Turn off LED connected to PORTB.0
    I have had the high low operators fail to work for me and I do not know why.
    EDIT: Make sure to hook up that ground wire to vss pin 5
    Apr 2009
    Default Hi Joe
    I tried with the code which you gave joe. still i have the same issue.
    i appreciate your patience, i am just wondering about the diagram, please check the attachement. i have tried with 2 microcontrollers. is there any way of checking the microcode programming / fault pic .
    Hi shafi008,
    Ok this picture looks much better, I HAVE FOUND, on some low cost breadboards, the power bus strips have gaps that must be bridged. I have some like that which needed 3 jumpers to make the strips have continuity all the way across, so just for practice, please use a meter or led and check yours, just to make sure.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
