Its a little hard for me to follow your "diagram", but it doesn't look like your resonator is grounded to me..... The center pin should go to ground, no?
Also try trisb command.
Check out:
http://www.picbasic.co.uk/forum/showthread.php?t=7906
Walter
Check out:
Walter
Hi one of the document says the VSS should be connected to the middle pin of resonator, thats why it was connected to Vss and the pullup resistor i have used for MCLR is 4.7K. the other end of pullup resistor the voltage was around 2+_ volts.
As you said today let me try by connecting the resonator middle pin to Ground , i will post you the output later.
Hello Syed,
I am looking at the picture you posted, you have a wire going from the center of the resonator to pin 5 of the PIC but no wire from Pin 5 to ground. It must be grounded to the 5v supply, otherwise the PIC receives no power.
See Attachment:
<img src=>http://www.picbasic.co.uk/forum/atta...1&d=1240594618
Hi Guys,
Bad luck i tried changing another Pic16f84a
no work, i tried with multiple resonators and 4mhs with 47 / 10 pf that also doesnt' work.
here is the code file in two formats, probably i will update my cirucit picture tomorrow.
Code :
@ DEVICE pic16F84A
define OSC 4
TrisB = %00000000
loop:
High PORTB.0 ' Turn on LED connected to PORTB.0
Pause 1000 ' Delay for .5 seconds
Low PORTB.0 ' Turn off LED connected to PORTB.0
Goto loop ' Go back to loop and blink LED forever
and in Hex:
0000- 2828 018f 008e 30ff 078e 1c03 078f 1c03
0008- 2823 3003 008d 30df 200f 2803 018d 3ee8
0010- 008c 098d 30fc 1c03 2818 078c 1803 2815
0018- 078c 0064 0f8d 2815 180c 281e 1c8c 2822
0020- 0000 2822 0008 1383 1303 1283 0064 0008
0028- 1683 0186 1283 1406 1683 1006 1283 3003
0030- 008f 30e8 2002 1006 1683 1006 1283 3003
0038- 008f 30e8 2002 282b 0063 283c
I noticed when i take off the Vss pin then the led is constantly lighting up.
if i connect Vss then nothing comes up. no power in the pins . with the multimeter i checked the pullup capacitor
is giving me 1.24 reading and no power on the pins,
what would be the problem. Is there any way of tracing this where it is going wrong?
Hi Syed,
Try this code:
I have had the high low operators fail to work for me and I do not know why.Code:@ DEVICE pic16F84A define OSC 4 PortB = 0 ' set port latches low TrisB = %00000000 ' set portb as outputs loop: PORTB.0 = 1' Turn on LED connected to PORTB.0 Pause 1000 ' Delay for .5 seconds PORTB.0 = 0 ' Turn off LED connected to PORTB.0 Pause 1000 ' Delay for .5 seconds Goto loop ' Go back to loop and blink LED forever End
EDIT: Make sure to hook up that ground wire to vss pin 5
