Welcome into PIC world
Results 1 to 25 of 25
    Apr 2009
    Default Welcome into PIC world
    Hello This is my first time in PIC's world.
    I am using 16f84a with Melabs programmer.
    I am trying to flash a led at PortB.0 and here is the code and
    circuit diagram is at http://www.trendztechnologies.net/good.jpg
    loop:
    High PORTB.0 ' Turn on LED connected to PORTB.0
    Pause 1000 ' Delay for .5 seconds
    Low PORTB.0 ' Turn off LED connected to PORTB.0
    Goto loop ' Go back to loop and blink LED forever
    At all the ports i have 0.74 reading.
    LED is constant but it is not blinking.
    Could you please suggest me what's wrong with this.
    Syed
    Its a little hard for me to follow your "diagram", but it doesn't look like your resonator is grounded to me..... The center pin should go to ground, no?
    Also try trisb command.
    Check out:
    http://www.picbasic.co.uk/forum/showthread.php?t=7906
    Walter
    Check out:
    Walter
    Looks like the PIC is not hooked up to ground at all, notice the center pin of the resonator goes to the PICs ground leg but I see no ground wire there.
    Apr 2009
    Default Thanks for your reply
    Hi one of the document says the VSS should be connected to the middle pin of resonator, thats why it was connected to Vss and the pullup resistor i have used for MCLR is 4.7K. the other end of pullup resistor the voltage was around 2+_ volts.
    As you said today let me try by connecting the resonator middle pin to Ground , i will post you the output later.
    Hello Syed,
    I am looking at the picture you posted, you have a wire going from the center of the resonator to pin 5 of the PIC but no wire from Pin 5 to ground. It must be grounded to the 5v supply, otherwise the PIC receives no power.
    Hello Syed,
    See Attachment:
    <img src=>http://www.picbasic.co.uk/forum/atta...1&d=1240594618
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
