counting switch events beginner
Results 1 to 2 of 2
    mrpete's Avatar
    mrpete Guest
    Default counting switch events beginner
    I'm trying to get my pic16f690 to count every time a switch is pressed until it reaches a certain number. I've written a simple test program but it doesn´t work...Somehow the switch is being ignored, the if statement gets executed everytime. switch or no switch. what am i doing wrong?(I´m using the low pin count demo board)
    TRISA = %00100000
    TRISC.0 = 0
    TRISC.1 = 0
    led VAR PORTC.0
    led2 VAR PORTC.1
    butt1 VAR PORTA.5
    counter VAR word
    bcounter VAR word
    counter = 0
    bcounter = 0
    loop:
    high led2
    low led2
    if butt1 = 0 then
    high led
    low led
    counter = counter + 1
    endIF
    if counter>5 then blink
    goto loop
    blink:
    bcounter = bcounter + 1
    high led
    low led
    PAuse 500
    if bcounter<5 then goto blink
    counter = 0
    goto loop
    Have a look at the following, read all post there, this should give you some hints.
    You may also need to debounce your switch once you've discover why it doesn't work.
    There's another option, use an internal counter to do the job.
  1. Counting Events PIC18F8722
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st August 2009, 03:17
  2. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. Newbie - 16F628A and switch latching
    Last Post: - 19th May 2006, 03:35
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
