USART problems
Results 1 to 40 of 48
Thread: USART problems
    Talking
    The compiler is wrong, and I am right...
    Question
    Bruce, your code works perfectly when I process a single record. But I'm trying to add a paragraph at the bottom to read multiple records and failing miserably. I'm sure I'm screwing up the INTERUPT controls. As it stands, RESUME returns into the Doodle paragraph and stays there until my hair falls out (which will be soon).
    I tried to add ON INTERUPT immediately before the Doodle, followed by an INTCON=$80, but I must be messing something up doing that. I want the interupts to happen ONLY during the Doodle logic. I don't want it to fire up while I'm in the middle of extracting the bytes from BytesIn and writing them onto the EEPROM.
    Also, when you 'Trash any left over characters in RCREG buffer, I will be losing characters from the next record. I have to save that in a temporary array and load it back at the start of BytesIn somehow.
    Question
    Ok,
    I started again from your code, and modified one thing at a time. I've removed the comments to make it easier to read here (I figure you don't need your own comments).
    1. I saved the data from the 1st record by copying it into BytesGP[ByteGPN]. I need that data so I can write it to the EEPROM.
    2. I was able to get just Doodle under Interupt control.
    3. I was able to save the data from RCREG. There was indeed the 1st character from the next record in there. The data is stored in BytesBK[ByteBKN].
    ?. But I can't figure out what I'm doing wrong to get the rest of the 2nd record. I must be losing some kind of flag or something to tell USART not to hyperspace the rest of the 2nd record.
    define LOADER_USED 1
    LIST
    INCLUDE 'M16F87X.INC' ; PM header
    DEVICE PIC16F877, HS_OSC, WDT_OFF, PWRT_ON, BOD_ON, LVP_OFF, CPD_OFF, WRT_OFF, DEBUG_OFF, PROTECT_OFF
    XALL
    NOLIST
    define OSC 20
    define HSER_BAUD 19200
    DEFINE HSER_CLROERR 1
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    GP VAR BYTE
    BytesIn var byte[80]
    ByteCnt var byte
    BytesGP VAR BYTE[80]
    ByteGPN VAR BYTE
    BytesBK VAR BYTE[80]
    ByteBKN VAR BYTE
    X VAR BYTE
    EOM CON "~"
    OERR VAR RCSTA.1
    CREN VAR RCSTA.4
    RCIF VAR PIR1.5
    ByteCnt = 0
    ADCON1 = 7
    INTCON = %11000000
    PIE1.5 = 1
    GOTO Start
    WHILE RCIF
    BytesIn[ByteCnt]=RCREG
    If BytesIn[ByteCnt]=EOM then OutMsg
    ByteCnt=ByteCnt+1
    WEND
    RESUME
    OutMsg:
    HSEROUT [13,10,dec ByteCnt," Bytes Rcvd:",STR BytesIn\ByteCnt]
    FOR GP=0 to ByteCnt
    BytesGP[GP]=BytesIn[GP]
    BytesIn[GP]=0
    NEXT
    ByteGPN=ByteCnt-1
    ByteCnt=0
    ByteBKN=0
    WHILE RCIF
    BytesBK[ByteBKN]=RCREG
    ByteBKN=ByteBKN+1
    WEND
    GOTO Main
    On Interrupt Goto Main
    Doodle:
    FOR X = 0 TO 250 : PAUSEUS 20 : NEXT X
    INTCON=$80
    Start:
    ByteGPN=0
    WHILE ByteGPN=0 : GOsub Doodle : Wend
    ' BytesGP[ByteGPN] Data from BytesIn is saved here for EEPROM
    ' Place contents trashed from RCREG back in beginning of BytesIn
    ByteCnt=ByteBKN-1
    For X=0 TO ByteCnt
    BytesIn[X]=BytesBK[X]
    NEXT X
    HSEROUT [13,10,dec ByteCnt," Bytes Saved:",STR BytesIn\ByteCnt]
    GOTO Start
    I went for a nap after my last post and not 2 minutes later, I remember this:
    "If you just need to PIC to tell the PC to stop sending data, connect the PIC flow control pin to the PC CTS pin."
    Why not do something useful with the data received instead of wasting time in the doodle routine or writing everything received into another array?
    Once you receive the terminating character, write your data to EEPROM, then wait for the next packet.
    Also, you don't need all this;
    LIST
    XALL
    NOLIST
    Just drop in your fuse definitions like below, and leave the rest to PBP. It does all this for you.
    @ DEVICE PIC16F877, HS_OSC, WDT_OFF, PWRT_ON, BOD_ON, LVP_OFF, CPD_OFF, WRT_OFF, DEBUG_OFF, PROTECT_OFF
    This routine;
    WHILE RCIF
    ByteBKN=ByteBKN+1
    WEND
    Just clears whatever characters may have arrived after the terminating character was received. You want to be sure RCREG is empty & RCIF is clear before your next data packet shows up.
    At some point, you're going to need some kind of synchronization with your PC program sending your data. You can't just keep slamming data into the USART without doing something with it to clear the array, and you're going to need some time to write your data to EEPROM (without interrupts enabled).
    You do not want interrupts enabled when writing data to the EEPROM, so you will definitely want to implement something to let the PC know you're busy.
    Example scenario:
    PIC requests data from PC.
    PC sends packet with terminating character.
    PIC receives & stashes data in array until terminating character is received.
    PIC processes data.
    PC waits for signal from PIC to send next packet.
    PIC says OK, let's have it.
    PC sends next data packet.
    Two way communications is the key.
    Strip all the useless stuff out of my example. You don't need to send everything back to the PC terminal program or waste time in the doodle sub-routine. That was just an example showing how to receive streaming data, and key on the terminating character to find the end-of-packet.
    The time you spend in re-writing everything into another array, pauses, etc,, could be used for processing your inbound data, and let you setup & wait for the next packet.
    Note: Watch for stuff like this;
    Doodle:
    INTCON=$80
    Program flow will never reach INTCON=$80 because it RETURNs before landing on it.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Hi Bruce,
    I tried that, didn't work.
    "Once you receive the terminating character, write your data to EEPROM, then wait for the next packet."
    I tried that too, writing to EEPROM takes too long. The balance of data goes to hyperspace.
    "Just clears whatever characters may have arrived after the terminating character was received. You want to be sure RCREG is empty & RCIF is clear before your next data packet shows up."
    I can't exactly do that. Those characters sitting in the 2nd byte of RCREG and in RSR are the start of the next record.
    "You do not want interrupts enabled when writing data to the EEPROM, so you will definitely want to implement something to let the PC know you're busy."
    Yup, I only have interupts enabled in a small loop where I'm waiting for input. Besides CTS, which I can't get to work, is there another means of telling the PC to stop sending? It looks to me like the PC only listens to CTS at the end of his packet, not in the middle.
    "At some point, you're going to need some kind of synchronization with your PC program sending your data. You can't just keep slamming data into the USART without doing something with it to clear the array, and you're going to need some time to write your data to EEPROM (without interrupts enabled)."
    Do you have any idea how to do that? I've been going through pages 101 and 102 of the PIC 16F877 - USART ASYNCHRONOUS RECEIVER, and tried a ton of combinations using the flags they mention. Nothing works as expected.
    I can read my entire file without any problems, I just don't have time to process the records. I don't even have time to write to EEPROM without doing any record formatting whatsoever. I just set the location to 1 and write a record with zeroes.
    I have to momentarily interrupt the transfer, but I can't figure out how. Mister E has been giving this a try on his end and as far as I know, he's still stumped.
    Cool
    I think I figured it out.
    I lowered the BAUD rate down until I got to 2400 and things seem ok at first glance. Since the PC didn't want to wait or wasn't receiving the CTS flag fast enough, I guessed that lowering the transfer speed would give it more time to react.
    I have to go line by line to make sure no garbage crept through isolated areas, but the records line up and look good.
    to use CTS, you must ensure your terminal software handle it. If you're using MicroCode studio... it does'nt. Only RealTerm, or others with proper FlowControl setting CTS/RTS or DSR/DTR will stop when you clear CTS... in the worst case... $#%#$!#%$##*#$* hyperterm can stop too... if you're able to make it work... $%$### hyperterm ...
    BTW, at this poit, it looks like any of those terminal program i use, handle poor the flow control. I can stop, receive echo back a character of 4Mb files without any delay between receive, but if i place 5-10 or else uSec or mSec delay between each CTS i'm screw up. it's skip character, or i get garbage...
    still looks like the program stop serial out in the middle of a character or else.
    i figure i'll have to make my own software... again. we can't never trust somebody on this earth... still a pain to have a 100% workable program... Terminal 2.xyz is a big piece of &^&^%@@$%... sorry for the person who refer this program...
    As Bruce said, 2 way comm is the way... i agree. Probably better than CTS/RTS bulls.h.i.t... wich is probably just good enough to start transfer and stop at the end... or
    1. i'm missing something trivial on that.
    2. my terminal program is not good enough.. but for sure better than Hyperterm
  1. My USART problems..
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 31st July 2009, 02:00
  2. problem with USART
    By leemin in forum Serial
    Last Post: - 11th December 2006, 18:56
  3. USART TXREG Problems
    By BigH in forum Serial
    Last Post: - 11th January 2006, 01:30
  4. Replies: 5
    Last Post: - 1st December 2004, 13:49
  5. Synchronous USART problems... HELP!!!
    By moni in forum mel PIC BASIC Pro
    Last Post: - 14th November 2003, 20:00
