Bruce?
In short;
If you're not using HSERIN or HSEROUT, and just want to do everything manually by reading RCREG, handling over-runs, clearing RCIF, etc, then setup the USART registers manually as mentioned previously.
If you "are" using HSERIN & HSEROUT anywhere in your program, then you need to use the PBP USART defines - or select an oscillator speed that works with the default 2400bps.
I'm trying to receive a file to a PIC from a PC. I am able to manually send data via the serial window in Studio Plus to 2 consecutive HSERINs in the program, but I'd like it to be automatic. I'd like the 1st HSERIN to read the 1st variable, and then the 2nd HSERIN to read the balance of the record. As it stands I have to click SEND twice.
Do I have to do everything manually as you describe in option 1, or is there a method using HSERINs? Basically I'd like to set this up so it can read the entire file without manual intervention.
Specs: PIC 16F877, 20MHz crystal, COM1, MAX232CPE inverter, 19200 Baud, Windows Home XP, Studio Plus 2.1.0.8, PIC BASIC Pro 2.45a, caucasian, 6', married, 3 daughters, overweight, lazy and slowly going insane.
Thanks!
