You need to read RCREG to clear RCIF. I don't think you can clear it with pir1.5 = 0. If you don't clear RCIF you'll jump right back into the int handler each time you re-enable interrupts exiting your int handler.
Try something like this. Just change the LCD defines to match your LCD setup.You may need to edit your default PBP 18F452.INC header file to make sure you're turning on HSPLL for 40MHz with a 10MHz crystal.Code:DEFINE OSC 40 ' _HSPLL_OSC_1H & _HS_OSC_1H ' // Setup for dev board LCD pinout DEFINE LCD_DREG PORTB ' LCD I/O port DEFINE LCD_DBIT 4 ' 4-bit data from RB4 to RB7 DEFINE LCD_RSREG PORTB ' Register select port DEFINE LCD_RSBIT 2 ' Register select pin DEFINE LCD_EREG PORTB ' Enable port DEFINE LCD_EBIT 3 ' Enable pin DEFINE LCD_BITS 4 ' 4-bit data bus DEFINE LCD_LINES 2 ' 2-line LCD DEFINE LCD_COMANDUS 2000 ' LCD command delay DEFINE LCD_DATAUS 50 ' LCD data delay ' // Set USART parameters DEFINE HSER_TXSTA 24h ' Enable TXEN and BRGH=1 DEFINE HSER_RCSTA 90h ' SPEN & CREN = 1 DEFINE HSER_SPBRG 129 ' SPBRG val for 19,200bps @40MHz ' // Set USART interrupts, A/D, reg defs, etc,, SYMBOL RCIF = PIR1.5 ' Received character int flag INTCON = %11000000 ' enable global and Peripheral interrupt PIE1.5 = 1 ' USART receive interrupt enabled ADCON1 = %00000111 ' Turn off A/D all digital X VAR BYTE Teller var byte pause 1000 ' LCD power-up / init time lcdout $FE,1 ' Clear screen / home cursor on interrupt GoTo handle ' Point to int handler Main: lcdout $FE,1,dec teller ' Print to LCD clearing previous char for X = 0 TO 50 ' Loop for 1 second pause 20 next X goto Main Disable ' Interrupt handler Handle: while RCIF ' While RCIF is set, keep reading characters Teller = RCREG ' Reading character into Teller clears RCIF wend Resume Enable END
Commented out this line.
;__CONFIG _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
Add this below it, and save the file.
__CONFIG _CONFIG1H, _HSPLL_OSC_1H & _HS_OSC_1H
