now it seems to work, is there any log file or something where MPASMWIN will place the error's because it says the code contains error's but not what the problem is, it very annoying since my code is miles long
thx for your help already! (the serial systeem still doesn't work it now seems to have problems with the interrupt)
EDIT:
I now use microcode studio, I first used codedesigner it did not send me the error message's now I have the error message's but don't know how to fix this problem it all appeared after a format c: so I think some thing is installed wrong can't figure out what. this are the message's it produce:
18F452.inc 20 : Symbol not previously defined (_CONFIG1)
18F452.inc 21 : Argument out of range (not a valid config address)
18F452.inc 22 : Symbol not previously defined (_CONFIG2)
18F452.inc 23 : Argument out of range (not a valid config address)
18F452.inc 24 : Symbol not previously defined (_CONFIG3)
18F452.inc 25 : Argument out of range (not a valid config address)
18F452.inc 26 : Symbol not previously defined (_CONFIG4)
18F452.inc 27 : Argument out of range (not a valid config address)
and so on...
