Math Problem
Results 1 to 21 of 21
Thread: Math Problem
    I already used the following with good results.
    Curve Expert
    http://userpages.xfoneusa.net/~dhyams/cmain.htm
    Jul 2007
    It all works, just wondering how I will try to make exponents happen..
    What's your current formula?
    A third degree polynomial didn't fit?
    Jul 2007
    f(x) = 5167.68(0.98^x)
    could be more simple than you think
    http://en.wikipedia.org/wiki/Exponentiation
    Nope, bad link...
    Jul 2007
    well, I changed it up and am using three diff power curves to keep everything within 1 degree +/-
    only thing that is trouble is negative exponents.. tryin to figure out how to simplify it out so pbp can do it, but im am sucking on figuring this out. lol
    You could still build a lookup table and use some interpolation between some points, that should do the trick and way easy to implement.
    Lightbulb NTC linarization
    Hi, Folks
    I knew something REALLY simple was available ... but Where ???
    http://www1.produktinfo.conrad.com/d...K_5Prozent.pdf
    In the Application notes section ( You must scroll down ... the left side menu doesn't work !!! )
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  2. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 11:06
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 08:59
  5. Math problem...with picbasic pro
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 20:28
