Math Problem
Results 1 to 21 of 21
Thread: Math Problem
    Jul 2007
    Default Math Problem
    I need to figure out how to convert the non-linear AD Value to something more linear as far as the conversion goes.
    I figured out by reading a little on NTC thermistors, with the little data I have, I came up with resistance values that I believe are accurate within 1ohm
    Anyways, here is a link to the spreadsheet
    www.drivearu.com/Electronics/ntc%20thermistor.xls
    I am stumped!
    Jul 2007
    Ah, forgot that it needs to be the temperature range 100-250 degrees F
    When o I get the ability to edit my posts?
    Miami, Florida USA
    Erice1984,
    You can do a linear approximation but you are going to loose accuracy. Try doing a polynomial or exponential approximation. In EXCEL go to help and see how to add a trendline (it varies with the different versions of EXCEL). Obtaining the trendline is very simple. The trendline is going to give you a formula in the form of Y(X), X being the temperature and Y being the Resistance. Try with different options and settings until you get a good approximation. Then, you can use the resulting formula in your PBP program. That is with any value X (temperature) you can calculate a value Y (resistance).
    You should get the whole temperature range 100-250 degrees F in your graph before doing an approximation, so you get better results.
    This is one way to do it, which is very accurate. It all depends on the accuracy that you want for the resistance reading.
    Hope that this helps.
    Jul 2007
    Thank you very much!
    Wow, that was really easy!
    I lost accuracy but its in the place I don't care about!
    I already used the following with good results.
    Curve Expert
    http://userpages.xfoneusa.net/~dhyams/cmain.htm
    Jul 2007
    It all works, just wondering how I will try to make exponents happen..
    What's your current formula?
    A third degree polynomial didn't fit?
    Jul 2007
    f(x) = 5167.68(0.98^x)
  1. Line Graph, math problem...
    By TerdRatchett in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 05:20
  2. Math problem with string result
    By Lotondo in forum mel PIC BASIC Pro
    Last Post: - 15th November 2006, 11:06
  3. PicBasic Pro Math Problem??
    By Glen65 in forum mel PIC BASIC Pro
    Last Post: - 5th March 2006, 05:36
  4. Math Formula / Variable Problem! Help!
    By bwarp in forum mel PIC BASIC Pro
    Last Post: - 18th February 2006, 08:59
  5. Math problem...with picbasic pro
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 15th October 2005, 20:28
