need audible pulse out that varies "on time"
Results 1 to 9 of 9
    Feb 2005
    Question need audible pulse out that varies "on time"
    Hello,
    PBP
    16F88
    4MHz int osc
    I need to send a pulse out to a buzzer that will vary in on time. I need the program to continue running/taking readings while the pulse is generated. I have a variable that ranges from 1-64. I want to beep a piezo slowly at a reading of one, say 500ms. At a variable reading of 64 it would be a constant tone.
    I have no idea where to begin with this. Would I use HPWM?. Do I need to use timer1 with INT instead? Please help set me on the right track here.
    Mark
    Wink
    Hi, Mark
    Could you tell more about what you intend to do ???
    Especially the rate your program takes samples ... you need at least one clock @ 2Hz for your buzzer ( active one ??? ) , it's sure.
    But could it be derived from another clock ( sampling clock ??? )
    many solutions ... but we need to know a little much about your project !!!
    Feb 2005
    Made a mistake. I'm using a 18F4620 for this. 20mhz resonator. I'm communicating to a 16F88 but I need to have the piezo on the 18F4620. And the more I think about it I would like to have 1 beep per second at 0 and full on at 64.
    This is a small tracking unit for my RC plane. It could be used to track anything really. I am using two xBee modules to serially communicate between the two pics. The 16F88 is in the plane. When the handheld (18F4620) is in range they start to communicate. I send a command to the plane and then AT commands directly to the xBee to get the signal strength of the last packet. I'm using a directional antenna on the handheld to determine the direction.
    I'm not using the hardware serial port because I had to many problems. Things worked with software serial so that is what I stayed with. I'll probably move the xBee module off the hardware serial pins and use it for the LCD.
    ' 18F4620
    DEFINE OSC 20 ' 20Mhz resonator use HS when programming
    '********* Defines for Hardware Serial Port*******************************
    'DEFINE HSER_RCSTA 90h ' Receive enabled (pin)
    'DEFINE HSER_TXSTA 20h ' Transmit enabled (pin)
    'DEFINE HSER_BAUD 38400 ' Baud
    'DEFINE HSER_CLROERR 1 ' Auto Reset Buffer Overrun Errors
    '********* Setup registers, 18F4620 ****************************************
    CMCON = %00000111 ' Disable Comp
    ADCON1 = %00001111 ' all pins digital
    TRISA = %11111111 ' Set PORTA input/output
    TRISB = %11111111 ' Set PORTB input/output
    TRISC = %10111000 ' Set PORTC input/output
    TRISD = %11111001 ' Set PORTD input/output
    TRISE = %11101011 ' Set PORTE - set I/O bits 0,1,2 only leave rest alone
    LCDbaud CON 84 ' 9600bps
    RxDataBaud con 84 ' 6 = 38400 : 32 = 19200 : 84 = 9600 true, non-inverted
    TXDataBaud con 84 ' 6 = 38400 : 32 = 19200 : 84 = 9600 true, non-inverted
    RunLED var PORTC.2 ' pic pin 17 Program running
    RxData var PORTC.7 ' pic pin 26 connected to data-out on xbee
    TxData var PORTC.6 ' pic pin 25 connected to data-in on xbee
    SparkLCD var PORTB.4 ' pic pin 37 connected to data on LCD
    buzzerOn var PORTE.1 ' pic pin 9 buzzer on
    buzzerOff var PORTE.0 ' pic pin 8 buzzer off
    forceSleep var PORTA.5 ' pic pin 7 put remote to sleep for X time
    failSafe var PORTA.4 ' pic pin 6 get remote in area to report ID
    SW1 var PORTA.0 ' address select switch
    command var byte ' command sent to remote
    Xcommand var byte ' command executed by remote - reported back from remote
    address var word ' number/address sent to remote
    rssi var word
    valid var byte
    PORTC.6 = 1 ' PIC Tx pin(25) to Rx on XBee module
    address = 0
    command = 1
    high RunLED
    start:
    gosub getAddress
    gosub getCMD
    gosub sendCMD
    gosub getRSSI
    gosub displayLCD
    pause 250 'delay needed to read number on LCD
    goto start
    siglost:
    serout2 commands to print to serial LCD "no signal" ' takes ~17ms with pauses required
    GOTO start
    '*****//Subs//************************************************** ****
    getAddress
    read input pins on pic and set address. reads a four position dip
    getCMD
    read input pins on pic that set command for remote to execute. i have a loud alarm i can remotely turn on and off
    sendCMD
    serout2 TxData, TxDataBaud,[address, command]
    serin2 RxData, RxDataBaud, 250, siglost,[wait ("ACK"), address, Xcommand] ' echo back to confirm command was executed
    getRSSI
    communicate with wireless module, takes ~10ms
    'this is where i get 0-64 for signal strength
    'WANT TO SET BEEP ON PIEZO HERE
    displayLCD
    Serout2 RSSI data to serial LCD
    So from what I feel, you'll need to use HPWM. Look in your datasheet to spot the CCP1, CCP2 pins, see if they're free, and If so, well, it's just a matter of few lines of code then.
    Play around this one
    if Strenght= 0 then
            HPWM Channel, DutyCycle, Frequency
            PAUSE 500
            CCP1CON = 0 ' turn of PWM
            LOW YourBuzzerOut (or high depending)
            PAUSE 500
    if Strenght= 64 then
    Feb 2005
    thanks Steve,
    So this would require a pause of 1 second if the reading is zero? I can't afford that kind of delay. Is there another way?
    Mark
    Yes, you could start an endless timer interrupt (let's say few milliseconds) in which you check your value, then start the HPWM and keep track of the required delay.
    OR, enable the timer interrupt in your code, and assign a duration or flags for the HPWM.
    Bombay, India
    The way I would do it is to implement a soft PWM. I think it's been covered on this site already. Let a timer run in the background every mS. Give it a value for on time of the buzzer (0-1000mS) Every time the timer ticks, you can verify if the buzzer needs to be on or off. Now, all you have to do is give it a value from your mainline code.
    Feb 2005
    jerson,
    why soft and not HPWM? Honestly I'm not fully getting this...
    Mark
    Bombay, India
    MUC
    Frankly simply because I'm so used to it by now, I've never had to do the HPWM. I do a lot of temperature controllers with cycle times in the range of 1 to 30 seconds. So, ..... It's more a matter of personal taste.
    Jerson
  1. Pulse Capture and byte building
    Last Post: - 21st July 2009, 01:59
  2. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 08:42
  3. Replies: 3
    Last Post: - 13th September 2008, 17:40
  4. Unwanted output signal jitter
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 18th January 2008, 02:31
