Hser Baud Calculator
Results 1 to 1 of 1
    carl_schell's Avatar
    carl_schell Guest
    Wink Hser Baud Calculator
    Hi all -
    I am in the middle of a project and got tired of having to calculate HSER_SPBRG values - so I created a calculator in excel to do so more easily. I tried to make it very straight forward.
    All you do is type in 3 inputs (in the yellow boxes)
    1.) Ocs. Speed ie: 4
    2.) HSER_BAUD ie: 9600
    3.) HSER_TXSTA ie: 24h
    and the HSER_SPBRG value is calculated as is your actual Baud Rate and the % Error.
    It checks to see if you are using High speed or Low speed because there are 2 different formulas.
    Hope it helps you. It is an excel spreadsheet - but the forum won't let me post it as that - so I am attaching it with the as a ".txt" - so you will have to change the ".txt" to ".xls"
    =>Right click on link - click "save target as" - change type to "all" - and rename extension to ".xls" - this should work -
    Best Regards,
    Carl
    PIC Development Boards with Bootloader!
    www.schellelectronics.com
    Free shipping worldwide
    e-mail: [email protected]
    P.S. -
    Here is a sample of my Define Statements:
    DEFINE OSC ' Sets your Oscilator Speed (in Mhz)
    DEFINE HSER_BAUD 9600 ' BAUD Rate ( Bits Per Second - BPS )
    DEFINE HSER_SPBRG 129 ' Baud Rate Generator Register Value (0 to 255!)
    DEFINE HSER_RCSTA 90h ' 90h Sets Serial Port Enable and Continuous Receive Enable
    DEFINE HSER_TXSTA 24h ' Sets Tx Enable and Either High ("24h") or Low ("20h") Speed
    Last Post: - 8th March 2010, 20:58
  2. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 00:39
  3. Auto Baud Rate Detection
    By mytekcontrols in forum Serial
    Last Post: - 31st October 2005, 02:17
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
  5. Baud Rate and Timing Calculator
    By picnaut in forum General
    Last Post: - 23rd January 2004, 16:48
