Count?
Results 1 to 10 of 10
Thread: Count?
    Default Count?
    I obviously don't understand how the COUNT instruction works. The PBP manual says "The resolution of Period is in milliseconds. It tracks the oscillator
    frequency based on the DEFINEd OSC." In the program below, the period is 1000msec., or 1 second. When I apply a 66 hz. squarewave to RC5, I the LCD says 66. When I change the period to 2000, it says 33. Shouldn't it say 132? Also, if I change the period to 500, the LCD says 33. I don't get it.
    ;****16F946:
    Pause 10 ;for ICSP
    @ __config _WDT_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_ON & _INTRC_OSC_NOCLKOUT
    OPTION_REG = %11000000 ;pullups disabled, rising edge, no prescale
    ANSEL = 0 ;all pins digital
    CMCON0 = 7 ;comparators off
    ADCON0 = 0 ;ADC's off
    WDTCON = 0 ;WDT off
    TRISA = %00000000
    TRISB = %11000001 ;switches on RB6,RB7, INT on RB0
    TRISC = %00000000 ;LED on RC5, LCD bias on RC3
    TRISD = %00000000
    TRISE = %00001000 ;MCLR on RE3
    TRISF = %00000000
    TRISG = %000000
    OSCCON = %01100001 ;4mz. mhz. internal
    LCD_DB4 VAR PORTB.1
    LCD_DB5 VAR PORTB.2
    LCD_DB6 VAR PORTA.7
    LCD_DB7 VAR PORTA.6
    LCD_RS VAR PORTB.3
    LCD_E VAR PORTD.2
    LCD_Lines CON 1 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 2 ' Data delay time in us
    LCD_COMMANDUS CON 20 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    define OSC 4
    W1 var WORD
    X1 var word
    X1 = 0
    PORTC.4 = 0 ;leds off
    PORTD.3 = 0
    count PORTC.5, 1000, W1
    lcdout $fe,1, dec W1
    pause 10
    goto Main
    Any help will be greatly appreciated.
    Probably you've hit one limitation of COUNT.
    Try this one
    @wTimer1 = TMR1L
    wTimer1 var word EXT
    T1CON = %00000111
            'xx--x---- Don't care
            '--00----- Prescaler 1:1
            '-----1--- Do not synchronized external clock input
            '------1-- External clock from TOCKI pin (Rising edge)
            '-------1- Enable Timer1
            wTimer1=0  ' clear Timer1
            pause 1000 ' acquisition time
            lcdout $fe,1, dec wTimer1
            pause 10
            goto Main
    And ho, before trying the above, don't forget to set RC5 as an input first...
    DOH...
    Should have wrote T1CKI instead of T0CKI... silly mistake... oh well, it's just comments
    HAVING THE EDIT BUTTON BACK WOULD BE REALLY NICE, BUT IT STILL SEEMS TO BE A REALLY TOUGH THING TO IMPLEMENT!!!
    Returns the same here.
    Yep. Just tested one with with a 66hz signal, and it does indeed return 132.
    That's what it should return.
    Are you sure you're not changing anything else when you're testing it with 2000 as the
    period?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce, I just did it again with exactly the same code as posted. The ckecksum is 3174 with 1000, and 3160 with 2000. Could you check your checksums? I'll check the incoming pulses with a scope later tonight, to make sure nothing's changing there.
  1. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  2. Can't get COUNT to count
    Last Post: - 24th March 2009, 00:14
  3. Count pulses between VARIABLE TIME
    By RodSTAR in forum mel PIC BASIC Pro
    Last Post: - 15th October 2007, 13:44
  4. Multiplex Display with count comand
    By mdaweb in forum mel PIC BASIC Pro
    Last Post: - 16th October 2005, 05:09
  5. Count command
    By hawk72501 in forum mel PIC BASIC Pro
    Last Post: - 6th September 2005, 20:04
