Hello Guys,
Has anyone tried this LCD controller with LCDout?
Thanks!
Daniel.
Hello Guys,
Thanks!
Daniel.
YES !
Nothing special, just characters table slightly different ... very slightly !
Hello Alain,
I tried the SPLC780D controller, but I couldn't make the 8x2 LCD to work.
But, my code is working fine on a 16F877 with a HD44780 controller (20x2).
Any advice on how to configure this controller is much appreciated.Code:DEFINE OSC 20 ADCON1 = 7 DEFINE LCD_DREG PORTD DEFINE LCD_DBIT 4 DEFINE LCD_RSREG PORTC DEFINE LCD_RSBIT 6 DEFINE LCD_EREG PORTC DEFINE LCD_EBIT 7 DEFINE LCD_BITS 4 DEFINE LCD_LINES 2 DEFINE LCD_COMMANDUS 2000 DEFINE LCD_DATAUS 50 Pause 500 LCDOut $fe, 1 LCDOut "Hello Word" End
Thanks!
Daniel.
Hi, Daniel
Could you post your LCD ref. ... I use every day a SPL controlled 2x16 Display instead of a classical 44780 , aboard my EasyPic5 Board.
So, I'd recommand you to check twice your LCD Wiring ... R/W pin grounded ??? Contrast set ???
To the end you could try LCD_COMMANDUS 2500 ... I noted my 2*8 LCDs to be a bit " lazy " ... and they need 2000 at least.
Did you try ... another 2x8 LCD ??? a damaged device is always possible ...
Hi Alain,
Well, I tried 2500 on the LCD_COMMANDUS and it's still not working.
I have a working 16F877 with a 20x2 LCD (HD44780) that works great and I use this for debbuging.
So, I replaced that LCD with the 8x2 LCD (both have pins, so nothing to solder on them) and what it does is the following: first, all the characters on the first line went black and the it clears the screen. But. I'm not seeing the text I'm trying to write.
This is the information I have on this LCD:
Everything should be fine, but I'm missing something.
Thanks!
Daniel.
Hi, Daniel
http://www.fordata.cn/pdf/short/fdcc0802b.pdf
Check the Contrast PIN ... you should have ~ 0.5 v on it ...
