Saving COUNTs?
Results 1 to 11 of 11
Thread: Saving COUNTs?
    Default Saving COUNTs?
    I'm trying to accumulate the number of counts that the COUNT command returns on each pass though Main. I feel really stupid, but this code always saves and displays the most recent count:
    ;****16F946:
    Pause 10 ;for ICSP
    @ __config _WDT_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_ON & _INTRC_OSC_NOCLKOUT
    OPTION_REG = %11000000 ;pullups disabled, rising edge, no prescale
    ANSEL = 0 ;all pins digital
    CMCON0 = 7 ;comparators off
    ADCON0 = 0 ;ADC's off
    WDTCON = 0 ;WDT off
    TRISA = %00000000
    TRISB = %11000001 ;switches on RB6,RB7, INT on RB0
    TRISC = %00000000 ;LED on RC5, LCD bias on RC3
    TRISD = %00000000
    TRISE = %00001000 ;MCLR on RE3
    TRISF = %00000000
    TRISG = %000000
    OSCCON = %01100001 ;4mz. mhz. internal
    LCD_DB4 VAR PORTB.1
    LCD_DB5 VAR PORTB.2
    LCD_DB6 VAR PORTA.7
    LCD_DB7 VAR PORTA.6
    LCD_RS VAR PORTB.3
    LCD_E VAR PORTD.2
    LCD_Lines CON 1 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 2 ' Data delay time in us
    LCD_COMMANDUS CON 20 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    W1 var BYTE
    X1 var byte
    X2 var byte
    PORTC.4 = 0 ;leds off
    PORTD.3 = 0
    count PORTC.5, 1000, W1
    write 1,W1
    read 1,X1
    write 2,X1
    read 2,X2
    lcdout $fe,1, dec W1
    lcdout $fe,$c0, dec X2
    pause 10
    goto Main
    Can someone help, please?
    Thank you.
    May 2008
    Italy
    write 1,W1
    read 1,X1
    write 2,X1
    read 2,X2
    Should be
    write 1,W1.byte0
    write 2,W1.byte1
    read 1,X1
    read 2,X2
    Al.
    You're only saving the latest count.
    Try adding the new count to another var on each pass;
    W1 var BYTE
    X1 var byte
    X1=0
    PORTD.3 = 0
    X1=X1+W1 ' accumulate counts
    lcdout $fe,$c0, dec X1
    pause 10
    goto Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nothing surprising :
    1) you Write W1 in EEProm @1
    2) you read @1 an call it X1
    3) you Write X1 @2
    4) you read @2 and call it X2
    from that ... X2 = W1 ...
    The good question is :
    What did you intend to do ??? Store Odd passes result in W1 and even passes result in X2 ???
    Thanks for the help. I'm beginning to see the light, but my head's not completely pulled out yet! I know that on each pass, X1 will be greater than a constant(60 for example). I would like to total all of these difference numbers over a period of time. I know I may have to use WORD variables, but I just want to get the BYTEs working first! This code doesn't do it:
    X1 = W1 - 60
    pause 10
    goto Main
    Correction. Should have been W1 is greater than the constant.
    At least, do you have some readings?
    Yes, sorry. The last program displays 15, which is W1-60. But it does not become 30,45,60,75, etc.
  1. ADC Max Impendance and Power saving
    By Michael Wakileh in forum Schematics
    Last Post: - 28th June 2009, 20:29
  2. 16F to 18F context saving differences
    By brittons in forum mel PIC BASIC Pro
    Last Post: - 1st April 2007, 04:40
  3. FYI Daylight Saving Time in the U.S.
    By ccsparky in forum General
    Last Post: - 7th November 2005, 16:05
  4. Problem with saving to EEPROM...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 01:10
  5. I think my interrupt is not saving context properly?
    By royly in forum mel PIC BASIC Pro
    Last Post: - 6th December 2004, 18:21
