Trimming Servo
Results 1 to 2 of 2
Thread: Trimming Servo
    Oct 2006
    Edmonton AB Canada
    Default Trimming Servo
    I'm looking for some guidance.
    I'm using a servo to control a set of crossing gates on a model railway layout. The servo routine works fine, but the values of the pulse train are hardcoded, mostly because the servo appears to start slow and speed up, then slow down as it gets to the end of it's "rotation". Given that every servo has a slight difference in the pot, there is a slight difference in where the "fully up" and "fully down" numbers are.
    I'm looking for ideas on trimming the "up" and "down" positions. The solution would modify the existing numbers by some relatively small amount (+ or - 25) and should probably be single digits.
    It seems that a pot is easiest, although the calibration seems to be a pain, and an encoder would work, but can the output become single digits? Or, as I suspect, does somebody have a "been there, done that" really slick idea for me to give you credit for?
    Any suggestions appreciated
    Cheers
    Gary
    Wink
    Hi, Gary
    I suppose you have the source level program, so
    What I usually do for R/C devices :
    One jumper allows a programming sequence when placed before power up; if not, "normal " program starts :
    1) program 1 st position ( a couple of pushbuttons for + and - trimming are fine)
    2) take jumper off to valid setting and place it back.
    2) program 2 nd position
    3) take jumper definitly off
    The program then stores settings into the EEPROM and enters "its "normal" running.
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Problem with 12F629, servo and EEPROM
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 1st March 2008, 10:53
  3. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  4. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  5. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
