Change is bad
Results 1 to 40 of 46
Thread: Change is bad
    Bombay, India
    I have no objection to another level of verification if it will prevent spammers 'digging up the past'. Many times their post just bumps a long dead thread into activity which may not be good after all. As for Captcha, many sites I use make it hard even for a human to read Perhaps a different way to authenticate - like print a proverb (random) and ask the user to type the third and fifth word (random) of the saying. Similar to captcha, but more human readable. What do you think? It's admins call after all.
    Feb 2009
    Southern California
    I have to agree with Joe and Jerson. It is quite a hassle to enter a password every time. Maybe scale it by number of posts. IE the first 10 posts require authentication every other posts, then every 5 posts and by the time you get to 100 or so, just accept all posts unless someone flags the user. Also getting something that is human readable would be much better as everything seems case sensitive and a "P" and "p" look a lot alike when they are random text sizes at 45 degree angles.
    If there's less spammers, and give less problem to the admins using that method, I wouldn't care at all to type a password then.
    If there's an option for, User post counter could be used to determine if he's a spammer or not. On the other side, new users might find it a bit irritating.
    I guess time will tell.
    Quote Originally Posted by Luckyborg View Post
    That is 80% of my complaint, I do not see that well anymore anyway.
    Apr 2003
    Cambridge - UK
    Considering the number of users on this forum and the number of posts over the last 24hrs the level of negative response seems quite low.
    It would seem that users are:
    • not bothered by the changes
    • cant be bothered to make comment on the chnages (in which case i suggest that there not that bothered)
    • cant actually cope with the changes and so cant post a response
    maybe, a poll is required??
    Default looks something necessary ...
    Hi, Lester
    I had to refresh the code once or twice, as my eyes ( despite a good pair of glasses ) couldnt read the pattern ...
    could it be possible to have such "password" only once a session ??? ... a bit boring to repeat it at each post ...
    I see in the upper right corner the Forum "Welcomes me" ... so may be , We could HAVE TO log in once a session ??? ... and automatically being log out when leaving ... ( time limited cookie i.e. ... )
    California, USA
    * not bothered by the changes
    * cant be bothered to make comment on the chnages (in which case i suggest that there not that bothered)
    * cant actually cope with the changes and so cant post a response
    I don't even know what's going on here... what's changed?
    I don't seem to need to do anything "new & different" to post...
    steve
    May 2008
    Italy
    I am in the same situation as Steve stated.
    Al.
    California, USA
    It would seem that "Have not noticed any difference" should be added to the list.
    I did like mister_e and posted a photo to the test area, but nobody asked me for any "authorization" to do it.
    Perhaps it only targets certain browsers (firefox here), or certain IP addresses, or..?
    steve
    Feb 2009
    Southern California
    Red face Change is bad until they change it again
    They must have changed things around again, because I had to enter in the security code for a while each time I posted a reply or even to do a search of the forum, but now it is gone. I incorrectly entered the code 3 or 4 times for a single post as I couldn't read them correctly. Hopefully they found an easier way to get the security they wanted.
    David
    Feb 2009
    Southern California
    i forgot to add, that I'm on Firefox 2.0
  1. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  2. encoder port change
    By l_gaminde in forum mel PIC BASIC Pro
    Last Post: - 18th September 2009, 20:41
  3. pic18f4520 baud rate change to 115200
    By caltex88 in forum mel PIC BASIC Pro
    Last Post: - 30th September 2007, 09:41
  4. HELP !!! How change the voltage of a pin ????
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 21st August 2007, 21:55
  5. help!! With Keypad change
    By clare1 in forum mel PIC BASIC Pro
    Last Post: - 12th December 2006, 22:13
