This is a problem I've encountered for years on several different chips and have always just kind of ignored it. I have a problem using the Hserin command on initial power up. Below is a stripped down version of my code. Basically I power up the chip and wait a little while then send a burst of data. that data is basically ignored, I send a second burst and it is processed as is every burst after. if I hit the reset button every burst is processed, but if I turn off the power and wait a few seconds before powering back up the problem comes back for the first burst of data. I've checked the overflow and framing error bits, and see no problem. There are only a few registers I can even think to look at, but nothing is popping out at me. it seems like it would have to be something obvious.
ThanksCode:INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts Clear DEFINE OSC 40 ' Set Xtal Frequency DEFINE HSER_CLROERR 1 'will automatically clear overflow errors stream VAR BYTE[80] 'the last stream in view_stream var byte[104] 'outsream converted to patterns a VAR BYTE 'loop counter variable b VAR BYTE x VAR BYTE 'loop counter variable B0 VAR BYTE B1 VAR BYTE B2 VAR BYTE B3 VAR BYTE B4 VAR BYTE B5 var byte pattern var byte new_stream var bit red_LED VAR PORTC.4 'red led CSALL CON %00000000 'Chip Select for all chips CSOFF CON %00001111 'chip select for no chips CSB0 VAR PORTB.0 CSB1 VAR PORTB.1 CSB2 VAR PORTB.2 CSB3 VAR PORTB.3 TRISA = %11101100 TRISB = %11110000 'inputs for upper half switches outputs for lower CS TRISC = %11001111 '0-3 for switches, 4-5 for LEDs, 6-7 for serial data TRISD = 0 TRISE = 0 PORTB = CSOFF PORTE.0 = 1 PORTE.1 = 1 PORTE.2 = 0 ADCON1 = %00001111 ;****************Using Darrel Taylor Interrupts**************************** ;----[High Priority Interrupts]-------------------------------------------- ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler RX_INT, _GetData, PBP, no endm INT_CREATE ;Creates the High Priority interrupt processor ENDASM red_LED = 0 'turn on red LED Pause 1000 top: TXSTA = $20 ' Enable transmit, BRGH = 0 SPBRG = 34 ' 1200 Baud @ 0.0% SPBRGH = 8 BAUDCON.3 = 1 ' Enable 16 bit baudrate generator RCSTA = $90 ' Enable serial port & continuous receive GoSub send_data countdown: 'count from 9 to 0 For x = 9 TO 0 STEP - 1 For a = 0 TO 79 stream[a] = x + "0" Next a GoSub send_data Pause 150 Next x end_countdown: 'check buttons @ INT_ENABLE RX_INT ; enable RX_INT interrupts RCSTA = $80 'clear CREN RCSTA = $90 'Enable receive mainloop: if new_stream = 1 then RCSTA.4 = 0 RCSTA.4 = 1 'clear over run error new_stream = 0 GoSub send_data endif GoTo mainloop send_data: 'this sub will send bit patterns via psp (non interrupt driven) to another chip Return '---[USART RX - interrupt handler]-----------------------[High Priority]--- GetData: hserin 1000,No232,[str stream\80\10] red_LED = red_LED +1 'heartbeat new_stream = 1 No232: @ INT_RETURN End
David
