Long shift register
Results 1 to 21 of 21
    Bombay, India
    How about inline assembly enclosed by ASM....ENDASM statements?
    That would defeat my goal. I wanted to see if I could do it all (or mostly) in PBP.
    Joe
    Quote Originally Posted by Joe Rocci View Post
    Joe
    Are the picbasic commands 'shiftin' and 'shiftout' too slow for you ?
    Quote Originally Posted by Chris Barron View Post
    Chris
    SHIFTOUT is an I/O function that toggles an output port with the bitwise contents of a data variable. SHIFTIN does the same thing in the other I/O direction.
    What I want to do is set up a 'virtual' 1000 tap shift-register in the PIC's memory and be able to clock data through it. It's basically a digital delay line in memory, commonly used for digital signal processing applications. I need to clock it at a well-defined rate and also be able to read any of the 1000 tap points at any time.
    It's quite straightforward in assembler, but I wanted to try to incorporate it into an existing PBP program using PBP's ">>" (shift right) and or "<<" (shift left) instructions instead of using assembler. I was hopng someone would tell me there are secret PBP system variables that capture the bits that are shifted OUT of an array variable so they can be shifted back IN to the next variable in the array. This way, a 63-word array could be set up as the 1000-bit shift-register, and bits could be clocked through the 1000 bits as though it were one long shift-register.
    Joe
    California, USA
    well, I guess that you can only have bit arrays up to 256 elements, but I was thinking something like this..
    bigarray 	var	  bit[256] 'Large array to hold data
    newdata	var	  bit   'newest bit to be shifted in
    index		var	  byte
    for 0 to 255
        bigarray[index] = bigarray[index +1]
        next index
    bigarray[255] = newdata  'put the newest data bit into the array
    Maybe with 4 big arrays you could shift through 1024 steps?
    Or have I missed the point entirely...
    Sep 2005
    Campbell, CA
    18F parts let you have arrays as large as memory.
    Charles Linquist
    Quote Originally Posted by Byte_Butcher View Post
    index		var	  byte
    for 0 to 255
        next index
    Byte_Butcher,
    I hadn't thought about a bit array. My thinking was stuck on word arrays, ">>" functions, and being able to get the bit that falls out the end of one word and automatically put it into the input of the next word in the array. In assembler. this is almost trivial.
    Your idea seems very doable, except that every bit has to be handled individually. I'm concerned about time, since I want to shift all 1000 bits in 100usec or less. Actually, I'd like to do 2000 bits in that time if I could.
    Joe
    Byte_Butcher,
    Joe
    Perhaps if you gave a few more clearer details other than you want to make a 1000 byte long virtual bit array. Some explanation about how many of the bits you need to read, how often, if you need to skip any chunks (as in filtering and the application of maths series) It seems that you might not be clear enough answers because yoiur application isn't obvious.
    If you can do it in assembler you should, regardless of what esoteric reason you might have for not wanting to do it, life is too short sometimes !
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 18:51
  3. Replacing shift register with PIC
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 7th April 2008, 18:31
  4. Shift Register Woes, specifically the STP16DP05
    Last Post: - 11th November 2007, 23:22
  5. Replies: 15
    Last Post: - 30th January 2005, 03:58
