IF - WHILE and variables
Results 1 to 6 of 6
    I know what you want to do, but unfortunately you can't do it.
    What you want it's something like
    MakePORTB CON PORTB & %00111110
    but this will not compile. What you may do is use a Macro, but there's no advantage in this case.
    btn_x = PORTB & %00111110
    Work, but only where it is called.
    You may use A timer interrupt to refresh btn_x, but still, there's no real advantages, and you also need another variable to confirm that btn_x have been refreshed.
    Assuming you want to poll some push buttons, then yes Timer interrupt could be interesting. That's how I deal with them most of the time.
    You can use the timer interrupt to read the push buttons, to confirm that it's not just a glitch and then, to do the debouncing. Now we talk
    If btn_x=2 would mean that the other inputs are all low, but PORTB.1
