IF - WHILE and variables
Results 1 to 6 of 6
    SWITZERLAND (french speaking)
    Default IF - WHILE and variables
    Hello,
    Trying different ways to make some code more efficient, I found that variables may not be used the same way in IF or WHILE commands.
    btn_x = VAR BYTE
    btn_x = PORTB & %00111110
    if btn_x = 2  then .... => this works
    while PORTB & %00111110 = 2 ... => this works too
    while btn_X = 2 ... this won't work (?!)
    In the case of IF, btn_x variable will be recognised as in the WHILE, it will not as long as I don't write it as in the code above.
    I understand the difference between both commands functionalities; it is about to know why they can't be handled the same way.
    Roger
    flotulopex, Some more code would be nice... I havent had any problem with the way you are using them.. Some more code however might solve the problem...
    I know what you want to do, but unfortunately you can't do it.
    What you want it's something like
    MakePORTB CON PORTB & %00111110
    but this will not compile. What you may do is use a Macro, but there's no advantage in this case.
    Work, but only where it is called.
    You may use A timer interrupt to refresh btn_x, but still, there's no real advantages, and you also need another variable to confirm that btn_x have been refreshed.
    Assuming you want to poll some push buttons, then yes Timer interrupt could be interesting. That's how I deal with them most of the time.
    You can use the timer interrupt to read the push buttons, to confirm that it's not just a glitch and then, to do the debouncing. Now we talk
    If btn_x=2 would mean that the other inputs are all low, but PORTB.1
    Sep 2007
    USA, CA
    btn_x = VAR BYTE
    That is a one-time calculation. It never changes in your loop. You've got to update btn_x in the loop if you don't want a never-ending loop.
    Thank you All.
    The program is a "one-shot" reading (it is not a loop).
    Using the var is a little less words consuming (5 words) as if I use the full statement "PORTB & %00111110".
    Roger
