How does everyone debug their code?
Results 1 to 31 of 31
    Quote Originally Posted by HankMcSpank View Post
    ADCIN 0, DC_Level_IN ; Read the DC level on RA0 (pin 19)
    HSEROUT ["ADCIN Value = ", DEC DC_Level_IN]
    The problem with the above method is it's very hard on the eyes, as ithe data progresses across the screen left to right. Ideally I'd like each update to appear on a new line (or even just totally clearing the screen before the data is updated each time)
    Many thanks in anticipation.
    Hank.
    Try:
    HSEROUT [254,1,"ADCIN Value =  ", DEC DC_Level_IN]
    Damn, need the edit feature back . .
    Mar 2009
    Thanks for trying to help me out Joe, but it didn't solve my problem...
    (though I'm seeing lots of little rectangles after the data onscreen now - perhaps such unexpected results is a quirk of Microchips' UART tool window?)
    Mar 2009
    This works intermittedly...
    HSEROUT [10,13," Increase Gain, ADCIN Value = ", DEC DC_Level_IN]
    ...about 4 times out of 10, I get a new line!
    I've tried changing the baud
    DEFINE HSER_BAUD 2400
    ...but I just get garbage when i do (yes, I'm changing the setting in the UART window too!). therefore I'm thinking this might the general flakiness of the internal oscillator &/or the quirkiness of the Microchip UART window?
    Have you tried sending 2 separate lines, 1 to clear or give a newline and the second with your data? I would put a little pause in between too. You might research CHAR_PACING too
    In this order.
    hserout [whatever data, 13,10]
    this will work all the time as long as you have sufficient delay between all your HSEROUT, and as long as your baudrate is accurate.
    What you want is a ANSI terminal, those who accept ESC character, like the boring Hyperterminal, TeraTerm, RealTerm to name only but those. With an ANSI terminal, you can clear the screen, change font color, background color etc etc etc ( see http://www.pbpgroup.com/modules/wfse...hp?articleid=9 for reference)
    Unfortunately, PICKIT USART tool is not an ANSI one, so you have to deal with the pain or work around. If you're a bit familiar with Microsoft C#, you could modify Pickit USART tool (as it is open source anyways) to accept ESC characters, or to clear the screen when you receive, let's say, ASCII 225 or whatever else. That should be easy.
    <hr>
    I'll redo my explanation about USART tool debugging...
    Unless your current hardware don't use Serial communication, there's no need to use a switch, no need for HSEROUT either. What you do is to sit your PICKIT on the regular programming pins (MCLR, PGD, PGC) all the time, then you use DEBUG/SEROUT/SEROUT2 on PGD I/O. For this you must use TRUE mode.
    Clear enough now?
    I may try to post an example before going to sleep.
    Here's a quickie example.
    Note: I cut the trace from the pot to RA0 on my board, soldered a wire to the pot output
    circuit so I can connect the output from the pot to other A/D input pins.
    This leaves RA0 free for serial debugging with the PICKit2 USART tool.
    @ device pic16F690, intrc_osc_noclkout, bod_off, wdt_off, mclr_off, protect_off
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 0      ' RA0 = TX out to PICKit2 programmer USART tool
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 0     ' 1 = inverted, 0 = true
    DEFINE	ADC_BITS 10     ' Set number of bits in result
    DEFINE	ADC_CLOCK 1     ' Set clock source Fosc/8 "2uS"
    DEFINE	ADC_SAMPLEUS 50 ' Set sampling time in uS
    Q CON 1251              ' For 10-bit A/D +Vref = 5V : 5V/1023*256=1.251=Quanta
    ADval VAR WORD
    Result VAR WORD
    OSCCON = %01100000      ' 4MHz internal osc
    ANSEL = %00000100       ' RA2 = A/D in, rest digital
    ANSELH = 0
    ADCON0 = %10001001      ' Right justify, channel AN2, A/D enabled
    CM1CON0 = 0
    CM2CON0 = 0
    PORTA = %00000001       ' serial out pin idles high
    TRISA = %00000100       ' RA2 in, rest out
       ADCIN 2,ADval
       Result = ADval */ Q
       DEBUG "Raw = ",DEC ADval," Real = ",DEC Result DIG 3,".",DEC3 Result," V",13,10
       PAUSE 500
       GOTO Main
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2009
    In this order.
    Clear enough now?
    I'm hearing what your saying, but without an example to follow, I'm still left wondering how this is achieved.
    To set out my stall again - programming is new to me - I'm more of an old analogue electronics type. I can relate to a switch! I took one look a the PICKIT2 UART Tool connectivity diagram....
    & one look at the PICKIT2 schematic...
    & saw that it only needed two pins switched...then I can simply go between programming mode & UART tool mode with the flick of a switch. In the absence of anything else meaningful 9to me at least), I followed up that path.
    I can't believe just how much of a struggle it is for a newbie to get a 16F690 (probably the chip most newbies are exposed to as it comes with the PICKIT2) to do somethign as bland as send some stuff over a serial connection! (I don't mean about the h/w aspect, I mean getting the correct 'include' files & config, the register settings, the quirks about baud rates when using internal oscillators (as most newbies do)...then there's the h/w aspect .....what a lot of work!
    I misread your post, I thought you were sending to a serial LCD.
  1. N-Bit_MATH
    Last Post: - 16th December 2010, 15:48
  2. debug not working with MPASM assempler
    By santamaria in forum mel PIC BASIC Pro
    Last Post: - 4th March 2009, 08:51
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
