16F946 Instant Interrupts problem
Results 1 to 4 of 4
    Default 16F946 Instant Interrupts problem
    This program is supposed to count pulses on RB0 (INT), display count on LCD, and blink the LED. On power up, the LED blinks as it should, and the LCD displays zero, as it should. As pulses (~100hz) are applied, LED turns off and LCD displays the count. The count is updating at about a 1hz rate, for some reason. When the incoming pulses stop, the display shows the proper count, but the LED does nothing. I can't figure out why the TMR0 interrupt quits.
    Pause 100 ;for ICSP
    @ __config _WDT_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_ON & _INTRC_OSC_NOCLKOUT
    OPTION_REG = %11000000 ;pullups disabled, rising edge, no prescale
    ANSEL = 0 ;all pins digital
    CMCON0 = 7 ;comparators off
    ADCON0 = 0 ;ADC's off
    WDTCON = 0 ;WDT off
    TRISA = %00000000
    TRISB = %11000001 ;switches on RB6,RB7, INT on RB0
    TRISC = %00000000 ;LED on RC5, LCD bias on RC3
    TRISD = %00000000
    TRISE = %00001000 ;MCLR on RE3
    TRISF = %00000000
    TRISG = %000000
    OSCCON = %01100001 ;4 mhz. internal
    T1CON = 0
    TMR1L = 0
    TMR1H = 0
    T1 var word
    T2 var word
    SMCOUNT var byte
    LED2 var PORTC.5
    LCD_DB4 VAR PORTB.1
    LCD_DB5 VAR PORTB.2
    LCD_DB6 VAR PORTA.7
    LCD_DB7 VAR PORTA.6
    LCD_RS VAR PORTB.3
    LCD_E VAR PORTD.2
    LCD_Lines CON 1 ' # of Lines on LCD, 1 or 2 (Note: use 2 for 4 lines)
    LCD_DATAUS CON 20 ' Data delay time in us
    LCD_COMMANDUS CON 2000 ' Command delay time in us
    INCLUDE "LCD_AnyPin.pbp" ; *** Include MUST be AFTER LCD Pin assignments ****
    ;----[ Your Main program starts here ]----------------------------------------
    PAUSE 50 : LCDOUT $FE,1 : PAUSE 20 ; Initialize LCD (You may not need this,
    ; but some displays are picky)
    smcount = 0
    INCLUDE "ReEnterPBP.bas" ; Include if using PBP interrupts
    INT_Handler INT_INT, _CountRevs, PBP, yes
    INT_Handler TMR0_INT, _ToggleLED2, PBP, yes
    OPTION_REG = OPTION_REG & $80 | 1 ; Set TMR0 Prescaler to 256, leave RBPU alone
    @ INT_ENABLE INT_INT ; enable external (INT) interrupts
    @ INT_ENABLE TMR0_INT ; enable Timer 0 interrupts
    low PORTC.5
    low PORTC.4
    low PORTD.3
    lcdout $fe,1, dec SMCOUNT
    pause 10
    goto Main
    '---[INT - interrupt handler]---------------------------------------------------
    CountRevs:
    while PORTB.0 = 1
    wend
    while PORTB.0 = 0
    wend
    T1CON = 1
    while PORTB.0 = 1
    wend
    while PORTB.0 = 0
    wend
    T1CON = 0
    T1.HighByte = TMR1H
    T1.LowByte = TMR1L
    if T1 > 0 then
    SMCOUNT = SMCOUNT + 1
    TMR1L = 0
    TMR1H = 0
    @ INT_RETURN
    '---[TMR0 - interrupt handler]-------------------------------(Blinky Light)------
    T0Count VAR WORD
    ToggleLED2:
    T0Count = T0Count + 1
    IF T0Count = 256 THEN T0Count = 0 : TOGGLE LED2
    @ INT_RETURN
    Any help will be appreciated!
    If pulses stop while it's in the CountRevs interrupt service routine, interrupts are disabled,
    and you'll be waiting forever in this routine until pulses start up again.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thank you, Bruce. How do I fix it so it exits from the routine?
    You'll need to get rid of the WHILE WEND loops waiting for state changes on RB0.
    -Bruce
    tech at rentron.com
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 20:02
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. Problem using Instant Interrupts
    By Jerson in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2006, 17:35
