Multitasking Ideas
Results 1 to 7 of 7
    Ankara,TURKEY
    Default Multitasking Ideas
    I want to do two or more processes at the same time, I searhed on net and find some ideas for multitasking with pic mcu.
    And what you think about it?
    Electrical & Electronic Engineering
    Undergraduate Student
    Sep 2007
    USA, CA
    You can either use interrupts, or you can use a loop where you poll conditions to perform different operations.
    Just like Windows before dual processors, the PIC cannot multitask. It can only give time slices each task. It is up to you how to allocate the time slices.
    Actually I disagree... PICs can multitask...
    ... from another thread (to paraphrase a quote from BattleStar Galactica "all of this has happened before and will be again")...
    --- available from use of the SEARCH button ----
    Usually you need multiple or parallel processors to do multitasking. Most computers give the illusion of multitasking through a process of time-slicing - ie devoting a portion of the overall CPU time to a given job, then switching to another task. If done fast enough then you have your multi-tasking illusion (typical example is Microsoft Windows).
    Actually PICs do genuinely multitask quite well. They're able to sample an ADC channel, perform multiple Timer functions, execute PWM trains, catch data in the USART and perform Analogue Comparisons all genuinely simultaneously whilst your program is doing something completely different. It's called using the features provided within your PIC and the secrets of exploiting these multitasking features are... in the Datasheet.
    Sep 2007
    USA, CA
    Well, ok, the peripherals can multitask, but the code execution cannot.
    Yep. As far as hardware is concerned, they definitely can multi-task.
    As for firmware, nope. Not even the fastest controller can. They all execute program
    instructions line-by-line - no matter how creative the programmer is. And time-slicing
    is for sure not real multi-tasking
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Ankara,TURKEY
    I agree with him time slicing is not multitasking, it is another form of code execution line by line
    I think that if I use one more pic I can multiask comfortable. In my latest project I used a main controller Pic 18f452 and a slave pic 16f628 to do real multitask. And it really working
    I send slave pic processes serially,when it doing its process, main mcu does another things
    When the main processor doing program saving or something else, slave pic cut material,count etc. However it is a industrial machine,it work fine. Now it has no problem,hope it has no problem.
    Ankara,TURKEY
    And I couldn't use time slicing operation, for me it is so complex
    Thanks all
    Hasan.
  1. Any Ideas for a cheap touch sensor??????
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 19th October 2013, 01:33
  2. Ideas on ir-code for dimmer
    By tirithen in forum mel PIC BASIC Pro
    Last Post: - 14th February 2009, 00:22
  3. Timing inaccuracy - any ideas?
    By Optech in forum General
    Last Post: - 7th February 2008, 10:37
  4. Any ideas on how to accomplish this?
    By bartman in forum General
    Last Post: - 27th January 2007, 01:48
  5. A category for Project Ideas
    By Pic_User in forum Forum Requests
    Last Post: - 23rd June 2006, 08:29
