On Screen Displays (OSD) with PIC and MAX 7456
Results 1 to 7 of 7
    Here's few code example in Proton PDS. Should be easy enough to convert.
    http://www.picbasic.org/forum/showthread.php?t=10723&
    That's a neat and cute IC, a little pricey though...
    Feb 2009
    Was hoping to not have to spend 100 bucks on an eval kit. Anyone have experience actually implementing this?
    I never said that, I gave you links to it, so obviously you haven't go there yet.
    Hello,
    stop on by www.thesiliconhorizon.com
    we have 2 boards that use the max7456.
    one is powered by a 40 mips dsPIC.
    the other is a dev board that just has the max 7456 and you can hook it to whatever... (this is the cheaper solution.)
    stop on by.
    code is included with the techFX Motion OSD board.
    it also uses a GPS, optional accelo and an optional IMU.
    lots of goodies on it.
    thnx
    oh yah we also have a video of its output, however the output is whiter now than the video shows...
    but itll give you an idea of what you can do with it.
    we didnt use a custom character set with the max 7456,
    but we did implements a directional heading that scrolls and it works great.
    code is included with purchase.
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. max 128 + pic 16f877
    By supernono in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 14:45
