On Screen Displays (OSD) with PIC and MAX 7456
Results 1 to 7 of 7
    Feb 2009
    Default On Screen Displays (OSD) with PIC and MAX 7456
    Has anyone implemented an OSD using a PIC and MAX 7456 IC? Would love to see a schematic and code example.
    Have a look at their Evaluation Kit
    http://www.maxim-ic.com/quick_view2.cfm/qv_pk/5569/t/al
    They provide the whole schematic (which look really like the one in the DataSheet, what a coincidence). From there, it's just a matter of having fun to remove some not needed stuff, and connect it to your favourite PIC micro.
    They also have few app note, tutorials and software. Download everything, sit back and enjoy some reading
    You'll need to use some kind of SPI communication, SHIFTOUT may work, but for some reason, I feel it will be a bit too slow... worth a try, that's for sure.
    Choose a PIC with decent memory size and with MSSP port, and you're ready to discover the joys of head-banging and software/hardware design from almost ground zero.
    Here's few code example in Proton PDS. Should be easy enough to convert.
    http://www.picbasic.org/forum/showthread.php?t=10723&
    That's a neat and cute IC, a little pricey though...
    Feb 2009
    Was hoping to not have to spend 100 bucks on an eval kit. Anyone have experience actually implementing this?
    I never said that, I gave you links to it, so obviously you haven't go there yet.
    Hello,
    stop on by www.thesiliconhorizon.com
    we have 2 boards that use the max7456.
    one is powered by a 40 mips dsPIC.
    the other is a dev board that just has the max 7456 and you can hook it to whatever... (this is the cheaper solution.)
    stop on by.
    code is included with the techFX Motion OSD board.
    it also uses a GPS, optional accelo and an optional IMU.
    lots of goodies on it.
    thnx
  1. Serial VB 2005 pic 16f877a problems
    By Snap in forum mel PIC BASIC Pro
    Last Post: - 8th July 2013, 01:52
  2. max 128 + pic 16f877
    By supernono in forum mel PIC BASIC Pro
    Last Post: - 8th March 2009, 14:45
