Detect Power Failure
Results 1 to 12 of 12
    Thank you!!
    Default Just an idea.
    What happen to the USB power rail if someone reboot the computer or shut it down for a short period of time (if at all possible or allowed)?
    In this case a simple wall-wart transformer would do the job too.
    Mister_e
    Would I still use the optocoupler if I rather want to use a transformer?
    Thank you
    Koossa
    No real need for an opto-coupler in that case.
    May 2008
    Italy
    it must send something to the PC via RS232 and the PC must send me an SMS or email.
    koossa, The SMS IO Controller will do what you need sending via sms the status of the inputs every times there is a change. Download the project at this link:
    http://techni.caliti.es/blog/2008/12...ontroller.html
    and read the manual to see how to use it.
    Al.
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 19:30
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
