Detect Power Failure
Results 1 to 12 of 12
    Mar 2004
    UK-Midlands
    Red face
    I would detect the 5v from the PC's USB socket. When 5v disappears check again for about 400mS to allow for spikes then send your serial data to the other PC.
    Bob
    Great!
    I would try it!
    Will I use a Transistor to detect power on the USB Port?
    Mar 2004
    UK-Midlands
    If you are going to use a seperate 5v supply say the 5v from the other PC I would strongly recommend using an optocoupler to monitor the 5v.
    Bob
    Thank you!!
    Default Just an idea.
    What happen to the USB power rail if someone reboot the computer or shut it down for a short period of time (if at all possible or allowed)?
    In this case a simple wall-wart transformer would do the job too.
    Mister_e
    Would I still use the optocoupler if I rather want to use a transformer?
    Thank you
    Koossa
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 09:00
  2. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  3. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  4. 12 Servo's together does not seem to work, Power problem
    By macx75 in forum mel PIC BASIC Pro
    Last Post: - 13th December 2006, 19:30
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
