SER_BAUD is the baud rate of the serial port, or in other words data transmission speed.
Set the speed to be the same as the speed of the device you are communicating with. Both serial devices must be operating at the same speed for there to be complete and correct data transmission.
IF you are not communicating withnother serial device, turn off the serial ports using the control bits in the special registers.
Further comprehensive information can be found in the 'Help' option on the menu bar in Codestudio
